LOD Destroyer for 2020 JL Rubi. Any good at protecting from rock chips?
Whisky19
Vermont
Subaru, JEEP!!!!!!!
can front splash guards be used with these?Ie: Weathertec or RokBlokz? I installed the Raptor Side-steps( which I think look sharp) but from a protection standpoint( avoiding chips and dings on the rear panel and fender flare) I believe these ( LOD’s ) would work better? Below is a rear profile of what I have now in my 2020 Rubi..
Jeep Wrangler JL LOD Destroyer for 2020 JL Rubi. Any good at protecting from rock chips? 1593964370460
LOD Destroyer’s for 2020 JL
Jeep Wrangler JL LOD Destroyer for 2020 JL Rubi. Any good at protecting from rock chips? 1594033465957
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I just recently replaced the factory Rubi rock rails with a set of LOD Destroyer sliders. They've definitely helped to decrease the amount of rocks kicking up and mud down the side of the body.
Whisky19
Vermont
Subaru, JEEP!!!!!!!
You have no splash guards in addition?
xaugievike
Chicagoland
2020 Rubicon
headbarcode - would you mind a shot from the bottom side of your rails when/if you get a chance?
Headbarcode
LI, New York
Just wandered into this thread and saw this. Any specific angles?
Just for future reference, if you hit reply under a specific post it will add it to your post and send that person a notification. I could've responded to you much quicker.
xaugievike
Chicagoland
2020 Rubicon
Still learning the lay of the land sorry. I just want to have an idea of what the rocker area looks like from the underside with those rails attached. Thanks again - sorry for the newb error.
Headbarcode
LI, New York
No, nothing to apologize about. Just wanted to give you a heads up on how to get a quicker response. You got a notification for this post because I quoted your post. Lol
I'll take pictures tomorrow, as early as possible. So, you're wanting to see how much space there is between the slider and the body, right?
xaugievike
Chicagoland
2020 Rubicon
correct. thanks
Headbarcode
LI, New York
Let me know if there are any other specific angles or areas you'd like to see pics of.
I know you said underside, but here's a couple shots taken with the camera inline with the lower part of the rocker that bends inward. They designed an intentional gap between the slider and rocker of about 5/8", so if it takes a hard enough hit to flex the slider, it won't hit the body.
xaugievike
Chicagoland
2020 Rubicon
Jeep Wrangler JL LOD Destroyer for 2020 JL Rubi. Any good at protecting from rock chips? 20200720_104111
That is perfect - thank you greatly for your time.
