BritishGuy
- Matt
- May 17, 2019
- NW Houston, TX
- 2019 JLUR, Ocean Blue, 6sp. (SOLD)
That's perfect!!!
Starting to install my tune today. One note for both Livernois and us. The included instructions for plugging in the bypass cable are not for a wrangler. The canbus junction is directly behind the glovebox. Drop the glovebox like you are changing the cabin filter and it is down on the left. Super accessible once I found it.
Automatic here.Do you have an automatic or manual?
He isn't on here but a local customer we did this on let me know that at the Sand drags at Silver lake he was able to outrun a 6.4 Hemi swapped JL with E85 in the tank, so I was definitely glad to hear that.Anyone installed this yet? Curious to hear about it.
this, the dollars per mile is usually close on 87, but cheaper than premium.It’s so much cheaper to get e85 though, and with the power gains I think it would be worth it overall.
Thanks for that, yeah, they mush have shipped an old version of the instructions. I will make sure they start shipping out the newer copyStarting to install my tune today. One note for both Livernois and us. The included instructions for plugging in the bypass cable are not for a wrangler. The canbus junction is directly behind the glovebox. Drop the glovebox like you are changing the cabin filter and it is down on the left. Super accessible once I found it.
I can't wait to see this group start sharing their feedback on it!I'm about to pull the trigger on this as well, thanks for the info! Once you're all setup, please let us know which tune you're running and how you like it.
Check your PM'sI will. It will take me a bit as I also purchased a unlocked pcm from Livernois so I can keep my original pcm locked for whenever I sell/service the vehicle. Hopefully I will be running it next week.
We can send you our tuner in advance to get needed information from your current PCM to be able to get the new one ready to work.So do you need to take the new, unlocked PCM down to stealership to get flashed to your VIN first or is there another way to do it? I remember seeing some messages further back about this and loved the idea.
Vin, and a bunch of other info as well!No need to go to the dealer. Livernois writes it to my vin and sends it with the tune ready to go.
No problem!That's perfect!!!
Correct, no need to leave it plugged in. once it's programmed, it's ready to go. Although we do sell a window mount if you wanted to watch gauges with the device.@Livernois Motorsports the programmer doesn't need to stay plugged in after changing the tune from stock, right? How do we go about asking for a spare ECM since I don't see it on your site?
The tuner should send a command to turn off the radio behind the scenes, so this shouldn't be an issue.Question of the day for Livernois. A bunch of members here change out the factory 5" radio, myself included. I cannot power off my new 7" radio, am I safe updating the pcm with the radio on?
What part of Az?I am interested...I sent Livernois a detailed info request via their website contact email middle of last week and waiting for a response. One of my concerns living in' Hells Acres' (Arizona) with summer temps often well north of 115 degrees and premium gas typically rated at a high of 91 octane, are potential overheating / pre-ignition issues. Anyone in the Arizona desert have experience with this tune?
It can be tuned out but emissions usually takes a hit. This guy breaks it down very well.Add another manual owner interested in the removal of the rehang characteristics.
This is interesting, what gains were found with 93 on a stock jeep?Well, truthfully, these trucks SHOULD be running premium fuel right from the get go. They work with 87, and we can actually still make improvements, but it's still held back due to the high compression these engines
By having the throttle close faster. The tuner of my last car was able to eliminate the rev hang completely.How can it be tuned out??
If you want to PM me your email address I can look into the support ticket status.I am interested...I sent Livernois a detailed info request via their website contact email middle of last week and waiting for a response. One of my concerns living in 'Hells Acres' (Arizona) with summer temps often well north of 115 degrees and premium gas typically rated at a high of 91 octane, are potential overheating / pre-ignition issues. Anyone in the Arizona desert have experience with this tune?
So this was dependent on how it was tested. basically these learn to pull power back a decent bit with 87. so you need to have premium in it long enough that it allows the power to be put back in. if you do, they make 5-10 more HP on the stock calibration vs 87. In the case of the gladiator, he had only ran 93 since brand new, and it was still an under performer.This is interesting, what gains were found with 93 on a stock jeep?
I know you said your programmer can not do everything a tazer can. But what parameters can be adjusted with the hand held unit?
