Mike921921
I've had the tune for several months now and no issues. Mine wasn't pinging before though. I went with a spare ECU just for the piece of mind of a fail safe backup.
it doesn't do that, BUT, the ECM and cluster both store mileage. so you would have a mismatch since the cluster would not match either ECM once removed and driven with another. however, removing it in and of itself shows nothing.@Livernois Motorsports my dealer ship claims that if I swap out my JLU 3.6 ecu with a tuned one and then swap back my oem ecu down the track should I need warranty. That it logs when it was removed from the car and they would void my warranty. Is there any truth to that or just a dealer scare? Thanks
It indeed does come with transmission tuning. As for the trans tuning, this has a Chrysler built, licensed 8-speed based on ZF designs, with that said the clutches don't quite operate the same as as the true ZF built 8HP transmissions. so there are limitations to what we can do. With that said, it's far more responsive for sure!So does the tune come with both the engine and tranny tune?
If you can answer Livernois, is there anyway to do any “custom” tuning for the trans, i.e. rev matched downshifts in manual mode or quicker manual shift response similar to the logic on the SRT ZF8 factory transmission tuning?
I know it’s not a performance vehicle, but that functionality is one of the things I miss on the JL compared to my old Charger.
Every time I get close to pulling the trigger these fears pop up and I chicken out. Hope they get you squared away somehow. Are you working with a shop? I'd most likely be doing my own work so these kind of problems feel like bigger problemsDoes anyone else have Livernois’ tune with the Magnuson SC? After 5k miles it’s claimed both my cats and fouled all 6 plugs from running rich. Im at high elevation with ~83kpa/12psi. At this point, Livernois has left me stranded and I’m having regrets so I’m interested in others experience with this set up.
Small update review. It's been 2 months.
Transmission tune is still good. Keeping the Jeep in lower gear around town, but seems lately to almost revert back to normal state. 6 or 7th gear and only 35 MPH. There should be no reason this engine is running at 1k RPM's.
Engine wise. MPG's have taken a shitty hit, like I'm down to 15 MPG's. Most of my driving is slower in town, but still when I get out on the highway it's not doing much better. I'm getting about 320 miles in a tank, that's if I ran it dry and didn't go to the pump with a gas light. I still have the downshifting on slight inclines. These engines just don't have the power under 2k to keep normal flow of traffic.
I could be running extremely rich and need to get more air into the engine. Already switch to AFE dry. Possibly need to switch to Mopar CAI. OR I need to get the air out better.
Again I didn't buy this for MPG's, but I would like to be able to go 400 miles on a tank and not worry about it. If I'm roundtripping with the family, we will take the wife Expedition (love the Ecoboost and 10 speed).
Unfortunately we do not support the eTorque models. So for 21, that means Gladiator, and manual trans 3.6 only.Is there a tune for the ‘21 eTorque 3.6? The wife is jealous of my 2.0 Sahara acceleration…with 35’s and 4.56’s. She has the Rubicon. lol
Not offhand, but did you disconnect the battery? and if so, how many miles have you driven since? I know when we did the emissions test for the gasoline version, it took a crazy long time for those monitors to complete after programming it.Is there anything in the tune that could prevent the o2 and egr sensor from being ready for an inspection? I am having trouble passing inspection and other than changing speakers recently I cant figure out whats causing it.
that is probably it, more than likely the battery was disconnected. I believe on our truck it took like 900 miles for them all to run, it was insane. but that was the case stock and tuned.It's strange. No battery disconnect in 6 months or so. The only thing I did recently is replace the dash and knee speakers 2 weeks ago. Since then I have driven 800 miles or so. Last part is that the dealer fried my radio with an update so maybe they unplugged the battery. Still, I have driven at least 300 miles since then.
