Little things you discovered on your JL
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
Forgive this post if it's something everyone is already well aware of. Just discovered the setting to have the gauge cluster screen show the gear it's selected in automatic mode, not just the "D" it normally shows on the default setting. Now it shows "D1" or "D3" or "D7" or whatever, just like it does in manual shift mode where it has always shown "M1" or "M3", etc.
Love that change... I like seeing when and why it picks certain gears.
And man, it's nearly impossible to get the transmission to go into D8 in auto mode unless you're coming down a grade for a while while on the highway. Other than that, it just will almost never select 8, which I guess makes sense given how tall that gear is.
I’ve heard that 8th is not easy to hit, however on my 20 JL 2.0 running 285/70/17’s and stock gears I’m always in 8th at speeds above 65 on the interstate. Wonder why some do, some don’t?
JimmyZ
Jimmy
2021 2-Door JL Snazzberry Rubicon
Found a little hack on YouTube to ensure you’ll be able to unlock and start the vehicle if you lose your FOB. Modified the hack a little bit, but now I can rest assured I’ll get home.
what is the hack?
Aframedweller
Rob
Redwood City, CA
2021 JL Rubicon, 1997 ZJ, 2012 VW Golf R
what is the hack?
Essentially, you need to stash your spare key FOB somewhere well hidden inside the Jeep with the FOB battery removed. Take the physical flip door key off the FOB and hide that somewhere on the exterior. So when you lose your FOB somewhere deep in the forest or desert, just take the door key you hid, open the door, retrieve your FOB from the inside, put the battery in and you’re back on your way. The alarm will go off when you unlock the door, so have the spare FOB and battery ready to go.
Adventure.AS
Port Dover ON Canada
2020 JLUR
Just a FYI, the fob will start the Jeep without the battery.
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I hit 8th gear in the city at speeds above 45 mph with 37s all the time. 5.13 gears help.
wibornz
Ted
lansing, Mi.
Just so you know, a 10mm wrench or socket, you can remove the rear window out of a hard top of the Jeep and get in. Takes about a minute.
roaniecowpony
Retired Engineer
I knew the heated seat and steering wheel came on when you remote start and the temp gets around 40° but didn't realize that the passenger heat does not come. Now my wife wants to drive all the time.
She's been driving all along, maybe you just didn't notice.
Rock Hopper
2019 MOAB, 2015 Grand Cherokee, 2006 TJ, 2008 Bullitt, 2006 Cayman S
Retired Firefighter
Also, with a spring loaded center punch you can remove every window out of a Jeep and the hardtop. Takes about 1 second. 😂
Sorry, just a little humor to “break into“ 2021.
There is a LOT of great info here, keep it going!
Happy New Year to everyone.
wibornz
Ted
lansing, Mi.
Lol, does the occupation, " Retired from Corrections " have anything to do with this tip ??
No, a criminal would just break the window. What corrections did teach me is that nothing is indestructible or secure. Did you know for instance that if you tie a big knot in a bed sheet and soak the knot in the toilet then beat the knot against a concrete cell wall for 20 hours a day for a month, the concrete wall will crumble and fall apart. Thats why I always giggle when I see someone spend a couple hundred on a center console safe.
D&C Designs
