List of aftermarket wheels that are hubcentric
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
Why do you need an adapter? Thousands of people run nonhubcentric wheels without issues. Very overblown topic and waste of $ on adapters.
Re-Read my post. It is clear that an adapter is "NOT NEEDED", and I also outlined one reason not to use it...question is does an adapter "CAUSE" a problem?
Summary so far:
* Adapters cause over confidence and people tend to not torque properly.
* It appears that you could have a problem if the adapter metal material is dissimilar to the wheel material..that will cause corrosion.
* Plastic adapters will melt if over heated.
* Adapters won't fit all wheels
So far none of these spell absolute doom when using an adapter. The first item is the main reason why people are against the adapter, and is the most valid reason.
ChattVol
Tennessee
JLU 4 door
Summary so far:
:headbang::flag:
Tdkrum5
Ted
WA/AZ
20 White JLU Sport Altitude
So after reading this whole thread I am still a little confused. Everything is listed for a Rubicon. So for a sport or Sahara with 2.5 lift, lift people say 4.5 backspacing. What 17x8.5 or 9 wheel with 4.5 backspacing what offset should I get for a 35 to have good articulate and the tire not stick out vary far?
BamaJeep
Alabama
2020 JLUR Sting Grey
This sounds like an entirely dumb question at this point but is 71.5mm considered hub centric on a JL or is it a different diameter? I thought for sure it was 71.5mm but seeing things now that cause me to wonder. But that would mean this entire thread is wrong and that can’t be the case.
blnewt
blnewt
New Mexico
2019 Jeep JL Sport S, 03 Toyota 4Runner, Infiniti G37, Toyota T100 (Retired 74 CJ-5, 80 CJ-7)
It is 71.5mm, what was causing you to wonder?
blnewt
blnewt
New Mexico
omnitonic
Michael
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
I saw this thread, and had to chime in. I put a set of hub-piloted wheels on an old truck that was set up for stud-piloted wheels. I spent a little time in my machine shop, where I made sleeves or bushings or whatever that were a kiss fit inside the lug holes on the wheels, and a kiss fit slipping over the threads on the studs. Using three of these sleeves per wheel got them centered up really well. I was very impressed with the gigantic difference I was able to make in exchange for an hour or two on the lathe, and some thinking.
Tri-City Jeep
