likelihood of broken front body bolt?
rickinAZ
Rick
Phoenix
2021 Rubicon Diesel
I've read multiple threads about front body bolts breaking when installing sliders. Is this a likely issue, or a remote one?
Chocolate Thunder
Jeremy
It’s not a given, but it’s not uncommon. I personally didn’t break any.
rustyshakelford
Rock Sponsor (Level 1)
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
I've read multiple threads about front body bolts breaking when installing sliders. Is this a likely issue, or a remote one.
I’ve yet to break one but it’s on my mind anytime I have to loosen them for RSE step installs.
We also use an induction heater to soften the lock tight too
Brett
Terminex
Omaha
2019 JLUS
Fixing stupid....
The 2 tricks that i have seen that always seem to work are:
-heat the bolts
-Back off every half turn
Dkretden
Denver, CO
2020 JLUR 3.6L
There are a lot of reports of broken bolts on these boards As you have read. I think that there is a sticky thread at the top of one of the forums on this topic. I decided against using any product that would require me to tackle those bolts. Others have heated those bolts and had no issues. Still others claim that they heated the bolts and still had issues.
remote or common? I’d say that it happens enough to be a significant concern.
rickinAZ
rickinAZ
Rick
Phoenix
2021 Rubicon Diesel
Not to mention that the solution seems to involve invasive surgery to get to the broken part.
Craigzjeep
Craig
Washington State, transplant from Wisconsin
2019 Sting Gray, AudiA4, Dodge Promaster City
Telecom installer
I had to loosen one on each side last week for new rock sliders install and had no issues.
Ruri
Richard
JLURD, Gen 2 Raptor, 997.1 Turbo, F90 Competition
Not FDIC
Just get frame mounted sliders and you don’t have to worry about it.
Yup I installed my frame mounted sliders last week from White Knuckle Off Road.
I wouldn’t want the weight of my rig pressing on the aluminum cab anyways.
JeepSmash
San Diego
2019 Rubicon Unlimited
nice. I haven’t seen those ones yet. I did the LOD signature sliders.
ChrispyJL
chris
Rockaway, NJ
2018 Punk"N JLU Sport s
Building Mechanic
I didn't break any either, front 2 bolts were a MFer though.
Those 6 bolts wooped my arse lol.
Just don't use air tools to take them off
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
Brett
I got ours off without breaking one but I have a question about using the induction heater. I’ve got a mini ductor induction heater but I was worried that I would just heat the head of the bolt up and the heat wouldn’t get to the loctite. When you apply heat to the head using the coil how far does the heat travel down the bolt?
JEEPIDON
Charlie
Forsyth, Missouri
2018 Wrangler Rubicon JL, 2018 Wrangler Sahara JL, 2010 Dodge Challenger R/T, 2013 Ram Longhorn 2500, 2008 JK Wrangler Sahara
Retired - Business Consultant
Interesting you mention that. My 2018 Rubicon was an early build on January 3, 2018 but never hit the dealer until late in April. By brother is an engineer at Ram/Dodge (35 years) and researched why it took so long after completion to hit the dealer. Front body bolt was broken during assembly and at the end when it goes into the dread "J" status it was driven out to mingle with over 2,000 other jeeps that had some kind of defect to be addressed before shipping. What is interesting is that over 200 in the to be repaired inventory had a broken body bolt. So yes, early on many never made it out of the factory without a body bolt incident.
I've read where several users have broken a bolt screwing around with the sliders. I believe based on the first hand knowledge I have....proceed with the possibility of breaking a body bolt.
C
rustyshakelford
Brett
Navasota, TX
I do it a couple times and eventually the heat makes it way to the locktite. Works great, just takes a little while. I genuinely dread messing with them because if one breaks, any profitability for the day is gone. Im very clear about the risks and repair procedures if one is to break so the customer isn’t caught off guard or im stuck with an invasive repair on my dime
Brett
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
just removed mine to do the rusty's sliders, did not break them took my time with the fronts as they have red loctite on them. Was able to do it by going nice and slow with a breaker bar, had to put my whole body into but they came out. From what i read it seams mostly those that broke them used impact tools which i could see they are in there good.
Motor City Aftermarket
