JB3
I have a rhino rack now installed on my JLUR and I'm mounting rear and side facing KC lights to the rack. I'm struggling with how to route the wiring harness. I've seen reference to people using a grommet like this one https://scanstrut.com/products/off-road/electrical-accessories/ds30-p-blk-cable-seal-black-detail# but this is designed more for an install with a solid material being available for the screws to hold. I'm thinking about using the same setup but swapping the screws for small stainless steel bolts with a lock and flat washer on the interior of the JL roof. Of course, not drilling more holes would be great but I can't see how to avoid it unless i route wiring through the rubber seal at the rear window or through the freedom panels.
Either way I hold, drilling holes or direct routing a quick disconnect option would be great for those times when I want to remove the roof (including the roof rack and lights). I've seen mention of these quick disconnects, http://cnlinko.com/Products/65_9.html.
Any suggestions on hole drilling vs not, if drilling what location (i'm thinking passenger side just after the freedom panel join points and under the front of the rhino rack pioneer platform), and if drilling grommet and/or quick connect usage.
