Light weight 37" AT Tires vs heavier 35" MT Tires
laueddy
Seattle
2018 Jeep JLU Rubicon (Black - Hardtop)
It has been mentioned frequently that the JL Rubicon axle is good for 35" Tires, but running 37" tires off road can increase that risk quiet a bit. However, the total weight combined on MT can be much heavier vs AT.
As an example:
The stock 17 Rubicon wheel + KO2 AT is approx. 80 lbs. (22+58)
Total = 80 lbs
35x12.5R17 E Rated KO2 AT is about 66 lbs + Spacer + OEM Wheel
Total = 92 lbs
37x12.5R17 D Rated KO2 AT is about 69 lbs. Plus 1.75" wheel spacer, the combine weigh is approx. (22+4+69) = Total = 95 lbs
As for the MT, Toyo have 35" MT Tires weight as much as 80 lbs. Plus Beadlock wheel @ 40 lbs
Total = 120 lbs.
Does that make running 37" KO2 AT with stock axle pretty reasonable??
Squibbles
Albuquerque
GTI, Ranger
The weight is only part of it, if there’s lateral force on the bottom of 37 it has greater leverage on the axle compared to a 35. I’d bet you start breaking half shafts first.
Motor City Aftermarket
