Lift or no lift
DavidCJ
Jeep Wrangler JL Sport S
Are you liking the ride of the ridge grapplers? How much road noise?
Here is a picture (sorry about the angle) with no lift and some meaty NITTO Ridge Grappler 33’s.
johnparjr
New Caney, TX
2024 Jeep Wrangler Sahara 4xe
How is your rig doing offroad?
Just got some 33's on my Sahara and just curious how it would affect offroad flex and capabilities
Haven’t had any issues it’s been off-road and in this first picture you can see the rear flexing. I have even taken it on the Rubicon trail
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Jeep Wrangler JL Lift or no lift 72866AF6-20F1-41B7-8C8D-A0B45A04454C
Did you disconnect sway bars on this trail?
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
Have you made any upgrades or swaps on the jeep yet?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Not me you quoted, but disconnecting the front sway bar will make the ride more comfortable because you and your passengers heads won't be swaying back and forth over every little bump and rut, on even the most mildest of trails. Lowering tire pressures will also add to the comfort, even if not needing the extra traction of the larger contact patch.
ZenWorld
Los Angeles
2019 Jeep Sahara, 2019 Tacoma TRD Pro
OLD Thread but I took his advice and got myself some 33S and offloaded my Sahara! I did run into the issue of my back tire knocking my fender LOOSE! So I think disconnecting the SWAY Bar in a certain situation will knock your fenders off. I ended up upgrading to a 1.5 INCH Teraflex SPACER Lift and I've been solid ever since. I STILL RUN Into situations where I feel I could get a fender offed but not like before. If you are doing MILD roads you should be fine.
