Lift is on (Question about steering and spare tire)
jdhunt0
Kentucky
2019 Wrangler Unlimited
I installed my 2in lift this weekend. As I was expecting, my steering wheel is off center. I have to turn left to go straight. Does this mean I need to make the drag link shorter? Also, I got an error after driving a few miles that my traction control has been disabled. Is this caused by the steering wheel being off? If I fix the steering will the code go away?
I also cannot fit my 35in spare on my Sport. It seems most of the people on this forum have no issues with a 35. Is the tire mount on a rubicon taller? Are the plastic bumpers on the rubicon cut out more?
word302
Oregon
JLU
The drag link has to be lengthened, as you just made the side/hypotenuse of the triangle longer. The code will clear once you adjust the drag link. The problem with your spare may be new wheels? Might need a spacer. I would never mount a 35 to the tailgate but that's just me. Plenty of people do it. I just hope they aren't all complaining about it in a couple years.
Roky
Roky
Rubicon tire carriers are bigger than the ones on the sport.
jdhunt0
jdhunt0
Kentucky
Roky
Roky
Thanks. How would I go about getting the part number?
88297540AG I think this is it if not it will get you in the ballpark. There’s some on eBay.
STLYoungblood
St. Louis, MO
2018 Wrangler JLU Sport S Ocean Blue
HoundDude
New Jersey (i know, i know, i'm stuck here)
2019 Wrangler JL Sahara
rotate the drag link adjuster in (CW when viewed from driver side towards passenger side) to turn the steering wheel CCW
gpurp
North Texas
19' JL Sport 2dr
This is why I'm seriously considering a bumper mounted tire carrier. I'm concerned about the tailgate sagging over time. You know how things get saggy with age.
word302
Oregon
JLU
I got the Rough Country tire relocation and the reinforcement brackets for pretty cheap. I feel a bit of sag in my tailgate when I close it, but when it's latched, it all feels rock solid and at a good price.
Just remember that sag you're feeling is only going to get worse over time.
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
When 4 Wheel Parts installed my 33's and lift they said I have to realign front end and Steering Wheel to adjust for it. I picked up that day and drove great.
jdhunt0
jdhunt0
Kentucky
My steering wheel needs to go clockwise.
word302
Oregon
JLU
It's really pretty simple. You lifted your jeep. The distance between the pitman arm and steering knuckle is now longer. You need to make the drag link longer to compensate.
vavaroutsos
Pete
Scotts Valley, CA
This should be the case if the drag link was not adjusted when installing the lift kit. However, the OP says he has to turn left to go straight. This means he has to shorten the drag link as he needs the steering wheel to turn to the right to center it. So something doesn't seem right here unless the drag link has already been adjusted.
jdhunt0
jdhunt0
Kentucky
My drag link has not been touched.
word302
Oregon
JLU
Then it needs to be lengthened. I think we're all just mixing words with where "straight" is. If you lifted your Jeep without adjusting the drag link, then it should have pulled the wheel to the right. You need to lengthen the drag link to fix it.
