Lets see your 392 on 35's or 37's stock suspension or lifted...
alksion
Josiah
Brea, CA
21 Rubicon 392, 21 Sahara Altitude
Biz Owner
I believe you may have to carry the tire in the rear cargo area. Although I didn't try to put on the stock tire carrier, I have read elsewhere on this forum and on FB that the 37" may not fit on the stock tire carrier.
Safe travels and good luck.
This is not a true 37 inch though. If anyone can confirm for me? I’m already going to have the stock tires in the vehicle, so it’s gonna be tough to try to fit a sixth one in there. It would probably only be for a few days to a week.
boxs
Arizona
21 MB GLC63 Coupe, 21 Rubicon 392
Done working!
I pointed out my stock wheels to Discount Tire where I ordered my 35" KO2's and they said no problem. Their equipment then installed the tires without removing the rings. The 35's barely fit the spare tire carrier, so I can't imagine the 37's will. I was able to fit all 5 of my stock tires in the back, but it was FULL! Good luck!
Boxs
Young04
MA
Hydro Blue 392
Did you get the reinforced tailgate? If so they may fit.
alksion
Josiah
Brea, CA
Biz Owner
No I’m going aftermarket but trying to figure out the tire situation since I’m getting those installed first.
boxs
Arizona
Done working!
I have the MOPAR lift gate reinforcement. The 35" KO2 fit, but the tailgate barely would close because the tire hit the bumper. The KO2's are 34.4" per the BFG Webpage. There is no way anything bigger would fit on my Jeep. I have since installed a relocation bracket from Rough Country. All good now.
Boxs
Young04
MA
Hydro Blue 392
Boxs
That is odd because I have the same set up and I have plenty of clearance. Enough to think 37s may fit.
boxs
Arizona
Done working!
That's why I said 37's would not fit MY Jeep. It seems there is no consistency, some have more room than others.
Boxs
Young04
MA
Hydro Blue 392
Boxs
Agreed there is inconsistency. I'm just surprised there is that much.
SSWIM
Sam
Too Many
Yea, the 37" isn't going on your factory carrier. Nope.
Sam
RivaDriver
NorCal
2021 Rubicon 392, 2002 Ferrari 575, 2018 BMW X6
Off topic question: Does the Bumper mounted bar interfere with the front camera vision/scope? & You have the set up I’ve been trying to find! Can you reply with your front bumper build out please? Would appreciate it!!
Warn Zeon 10-S Platinum Winch - #92815
Warn OEM Bumper Winch Carrier - #101255
Warn OEM Bumper Guard Tube - #102355
Warn 1" Black Fairlead - #100333
Factor 55 Ultrahook
The guard tube does interfere with the front camera a bit but not terrible. Here is a photo from the cockpit. Hope this helps.
ozon8r
Denver
2021 392 Hydro Blue
Factor 55 Ultrahook
Hey John,
Did you have any trouble re attaching the top two inside bolts on the OEM bumper with the Warn Zeon 10s winch? I went with Maximus 3 winch plate placing the winch aft as much as the grill would allow and the two top inside bolts on the OEM bumper are right next to the Warn winch preventing me from attaching the nuts. So, I have six of the eight bumper bolts and nuts reattached. And the bottom two inside bolts were pretty tough to re attach but got em on with some finger and arm contortionist moves.
RELBUS
RELBUS
Chicago
97 TJ , 21 JLUR 392
For the guys who have installed a Warn zeon, how much did the winch drop the front end with stock suspension? Thinking I will need to add a 1" spacer to compensate for the weight.
ozon8r
Denver
2021 392 Hydro Blue
3/4 inch for me. I went with the 10s and used the Maximus 3 winch plate. Of note, I could not get the top inside OEM bumper nuts back on the bolts. So running 6 of the 8 nuts. The Warn winch housing was literally 1/8" or less away from the top inside bolts, not enough room for the nut to go back on. And the bottom inside bolts/nuts were a PITA but back on and secured. No issue with the outside nuts either side.
RivaDriver
NorCal
Hey John,
Yes, the top two bolts were challenging to tighten. It took quite a while to figure out the right combination of 18mm deep socket and extensions to get it done. I watched many install videos prior to the installation and it seems pretty much everyone found tightening these bolts to be a challenge.
Tazer JL - Z Automotive
