Krondor
The Sting Gray Willy's really is a perfect combination. Congrats!Picked mine up Friday and I'm in love.
Looks good! Don't forget to send in for the $100 rebate on that bumper.New Venator bumper with Warn Evo VR12
Yes, I did. Learned about the rebate from here. Thanks. The Venator / Winch was a good projectLooks good! Don't forget to send in for the $100 rebate on that bumper.
Good to hear. Now that you've done the install, Do you think it's possible to install the bumper first, and install the winch at a later time (without needing to remove the bumper)? Also, Any idea how much the bumper weighs?Yes, I did. Learned about the rebate from here. Thanks. The Venator / Winch was a good project
Absolutely, you can install the bumper and then install the winch later. You would want to cover the hole where the winch would be (just for aesthetics). To install the winch later, just remove the top cover. Everything else stays bolted down.Good to hear. Now that you've done the install, Do you think it's possible to install the bumper first, and install the winch at a later time (without needing to remove the bumper)? Also, Any idea how much the bumper weighs?
Thank you! I really appreciate the install tips. I will most likely be placing my order for the bumper today.Absolutely, you can install the bumper and then install the winch later. You would want to cover the hole where the winch would be (just for aesthetics). To install the winch later, just remove the top cover. Everything else stays bolted down.
I don’t know the weight, but I did the install by myself and it was reasonable. Best part, it did not compress the suspension more than 1/8 of an inch. I was worried I would need a level kit.
There are 4 major parts: Top cover, winch plate/frame, skid plate and the tow hooks. The top and skid plate are light. The winch plate is maybe 25-28 pounds. The tow hooks are surprisingly heavy, maybe 8-10 lbs each.
Best tip I got on the install: don’t tighten anything down until your done. Very easy project.
Stance looks perfect.Finally got everything installed!!
Mopar 2” lift, Mopar wheels and 37” KM3’s
The weather finally cooperated to where I could hand wash it.
2 door Sting Gray Rubi - great choice!
Thanks!!Stance looks perfect.
