babybryce
Installed these headlights and these turn signals, previously running halogens. Halos on the headlight are supposed to function with DRL's in the fender flares. Everything is wired up and functioning properly in accessory mode (engine not running). Crank the engine and the halos start cycling through their startup process 3 times and shut off.
I come to the conclusion that I either need a dealer flash or a programmer to flash the ECM. So I go the programmer route and order a Tazer JL mini. I get the Tazer installed and go to the lighting submenu and change both the headlights and turn signals to now run LED and reboot twice. I crank the engine and turn the headlight dial to the fog lights enabling the DRLs and everything is working (halos and fender DRLs). I turn the headlight dial to auto and now the halos are no longer on but the DRL in the fenders are functioning. Has anyone had any similar issues or does anyone have any possible solutions?
