LED Sequential Fender Lights For Sport/Sport S
YellOhJL
Paul
Long Island
2020 Wrangler Unlimited Sport S
Network Engineer
Update:
Soooo....not as good as I thought, constant hyper flashing and "spasm" from the sequential LED. As a result I bought the JL Tazer Mini and flashed the car to run LED's and now it is finally working without any issue.
Which settings did you need to configure?
Also, would you mind taking pictures of the stock lens that these replaced? Most of the turn signal replacements from china appear to be for a Sahara/Rubicon (or stock non-USDM) , but they don't list that in the specs. If I was able to compare housing between the Sport and Sahara it would be easier to know what fits, but I have yet to see a picture of a Sport housing. Thanks.
emilboya
emilboya
Emil
TX
Hummer H3 (Sold) & Jeep JL
Process Engineer
Hello,
I noticed the same thing, I am at work and can't take a photo now. But email
Christine Wei <[email protected]>
I had her confirm 20x to make sure it fit the sport. She will make sure it goes expedited shipping as well
The setting on the Tazer was "LEDTrnSgn"- I just changed it to "yes"
JZ-TX
Alejandro
El Paso
2020 Wrangler Sport S
Got them installed. Plug and play, works fine. Except today I got a "turn signal out" error for a second. But everything still functions fine (so far lol).
the white DRL will only turn on with your headlights, not an actual DRL unless you wire it different.
and ignore the crappy iPhone pics
I'm liking these LED fender lights. I'm on the same boat; hard to find options for the Sport(S). The halogens look pretty horrible especially once you upgrade the headlights and fogs to LED. I'm also liking that bumper on your JL. Would you be able to share where you bought it from?
emilboya
emilboya
Emil
TX
Process Engineer
Thanks! It's a smittybilt Stryker bumper.
Also, the fender lights work perfectly after tazer. But what I did was buy some high top fenders and I think I like that better. The front pic shows high top fenders on left, sport fenders on right (gained about 2" of clearance)
so if anyone is in the TX area and wants these sport fenders with the LED lights just dm me
Black Jeep Convertible
NYC
www.amazon.com
'19 JLU Sport S 2.0T eTorque
Amazon Influencer 😂
YellOhJL
Paul
Long Island
Network Engineer
emilboya
emilboya
Emil
TX
Process Engineer
crap, I just noticed it also says not compatible with sport
contact the seller, you should be able to get a refund. The first link I posted are the only ones compatable with the sport fenders
YellOhJL
Paul
Long Island
Network Engineer
"So far" hopefully. I am hoping someone creates a replacement lens that mimics the stock LED but fits a Sport.
I tried these https://www.aliexpress.com/item/4000979769180.html
but they were not bright enough and there was not consistent brightness across the length.
JZ-TX
Alejandro
El Paso
I found these
US $103.68 20%OFF | New Led Turn lights DRL Daytime Running Lamp Fender Light for Jeep Wrangler JL Sport 2018 2019 2020
https://a.aliexpress.com/_mLtbAO3
Seller said they'll fit Sport and Sport S with the basic single bulb halogens. They look good, but I'm liking the other linked ones better. I'm emailing them and will hopefully be buying soon.
YellOhJL
Paul
Long Island
Network Engineer
I found these
I requested pictures of the lights actually installed in a Sport from a few of the sellers.
UPDATE: none of them could provide pictures installed in a Sport
YellOhJL
Paul
Long Island
Network Engineer
I found these
Did you make a purchase? I'm waiting till they come down to the price the are selling the ones for Sahara and Rubicon.
