LED plug and play on Sport S...?
obiwankabaldi
Lew
Rochester NY
Jeep Wrangler JL
Just attempted to install Morimoto Super 7 LED lights on my 2018 Sport S. They did not work. Had all the adapters and anti flicker harnesses but when I plug them in Nothing. Any other guys with Sport or Sport S try and have success? Thanks
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
Everyone that has LED's likes them, but if they were really honest with themselves, I'm sure they don't like them as much when they are oncoming, or tail gating you in a tall truck or jeep in the rain, and the stupid auto dim mirror only works when its dark. Glad I have Halogens and a standard mirror that dims more than the auto version, AND I can dim it when I want it dimmed and not only when its dark. If I had the choice of 2 identical vehicles.......except one had LED's. I wouldn't buy the LED equipped model. If you can't see far enough in the dark......slow down a bit.
I had a JL behind me at twilight on a clear morning..........LED fog lights on (not needed) and LED headlights. Its annoying. When approaching traffic, I turn off my non LED fog lights if they really aren't needed as I know they are likely in the face of cars that are much lower than my jeep.
Jeeps are up higher and makes it seem your lights are brighter to lower cars. I get flashed from others with my halogen low beams.
Kenny
Ken
Utah
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
I have Quake LED- Plug and play, 30 minute install. Adjusted.them - no one has flashed me - if done right they’re as good or better than halogen, IMHO
Alanscott1
Central NJ
2021 JT Mojave
A&P Mechanic
Or you can aim the headlights and fog lights correctly to mitigate blinding oncoming traffic.
I upgraded my headlights and fog lights to LED, and it made a substantial difference both in beam pattern cutoff and beam pattern width. For reference, I was getting flashed left and right when I first bought my JL, because the (halogen) headlights were aimed too high from the factory.
Haven’t been flashed once since I adjusted them.
Alanscott1
Central NJ
2021 JT Mojave
A&P Mechanic
Doesn’t work for low beam or high beam? Do you have a shot of the wiring harness coming off the headlight?
When I installed a set of JW Speakers in my JLR I had to reference the wiring diagrams I found here on the forum and from JW Speaker and rewire the light connector to work properly.
WXman
Central Kentucky
2018 Wrangler Unlimited
My experience exactly. Jeep is setting the beams too high from the factory on both the halogen and LED lights for some reason.
And, if a guy drops some Supernova V.4 or similar quality bulbs into their halogen housings they will become believers. Much more light, better beam pattern, and safer on rural roads.
I'm running the CrystaLux bulbs in my headlights and will switch to Supernova V.4 later down the road but I never get flashed by oncoming traffic, and the added light output is significant. Far more significant than the upgraded halogen bulbs on the market.
weeitsmikelee
Michael
Durrty Jersey
‘21 Wrangler392; ‘20 F-Pace; '15 XL883N; '82 CX500
Healthcare
I ordered led resistors and will play around this weekend to see what happens. My horn started sounding weaker right when one headlight went out. Fun ! :headbang:
