Leaving Chrysler cable attached?
Rescue119
Cory
Trenton, ON, Canada
2021 Jeep Wrangler Willys, 2021 Jeep GC L Limited
So got my Chrysler cable, obd2 blue tooth scanner today. Hooked it all up and used jscan to change stuff.
Worked great
Question is can I just leave that cable and obd2 scanner attached and tucked up under the dash? Or do I need to put it all back in?
I would put it back like factory for dealership visit of course
Rhinebeck01
Multiple places..
'18 JL Rubi, '24 Prevost M H3-45,'01 Harley FatBoy, '24 Cyberbeast
@Rescue119
Well, you may have a guy or gal post here that, sure.... it is aok to keep the Cable Adaptor for Chrysler 12+8 Programming Cable Connector, attached to the Security Gateway with the Bluetooth Scanner attached to it full-time..... but to do so is a real crap shoot so to speak.... SOoooo, don't do it!
If (and it can and does happen) the Bluetooth Scanner intermittently/inadvertently wakes up UConnect, you may/will come out to your JL , one morning, etc. and find the battery(s) depleted.. and you will be faced with a no start situation.
With that said.... Yes, It is aok to leave the Cable Adaptor for Chrysler 12+8 Programming Cable Connector, attached to the SGW full-time..... but do not leave the Bluetooth Scanner attached to that cable unless you are using the Bluetooth Scanner.
YES, when you go to the stealership Service Dept. for anything(even an oil change), do remove the Cable Adaptor for Chrysler 12+8 Programming Cable Connector and reconnect the 2 stock wires to the SGW. IF you do not do this and the Service Dept. Tech tries to use the WiTech ll to check something/to do an update the WiTech ll will fail to connect...
To anyone else reading this post... that's wanting to use a Bluetooth Scanner with their JL/JT...
I suggest you forget buying a Cable Adaptor for Chrysler 12+8 Programming Cable Connector like the guy in this post did...
Just but a $25 security bypass module. A nicer/cleaner/cooler, mouse trap so to speak.
This particular security bypass module works well with the JL/JT.
Connects at SGW and your Bluetooth Scanner gets plugged into the vehicle's OBDll port when you want to use the Bluetooth Scanner...
https://www.amazon.com/ECRI-Securit...coding=UTF8&psc=1&refRID=EGEZ7HHY3KQQ5P16EX38
OH, also buy a SGW Bypass Extension cable from Zautomotive at $29 and you will not have to go through all the SGW, contortions each time your JL goes to the dealership Service Dept.
https://www.zautomotive.com/product/z_sgw_ext/
Rescue119
Rescue119
Cory
Trenton, ON, Canada
@Rescue119
Well, you may have a guy or gal post here that, sure.... it is aok to keep the SGW bypass cable attached to the Security Gateway with the Bluetooth Scanner attached to it full-time..... but to do so is a real crap shoot so to speak.... SOoooo, don't do it!
With that said.... Yes, It is aok to leave the security bypass cable attached to the SGW full-time.. but do not leave the Bluetooth Scanner attached to that cable unless you are using the Bluetooth Scanner.
YES, when you go to the stealership Service Dept. for anything(even an oil change), do remove the bypass cable and reconnect the 2 stock wires to the SGW. IF you do not do this and the Service Dept. Tech tries to use the WiTech ll to check something/to do an update the WiTech ll will fail to connect...
Thanks for the advice. I didn't find it hard to get the cables at all. But I'm use to working on my 88 jaguar so I'm always in tight spots in wierd positions lol
Rhinebeck01
Multiple places..
@Rescue119
Curious.... what did you set-up with JSCAN?
Here are 3 that I use/like with my 2 dr. Rubi....
Fogs with High Beams:
ADAPTATION
---> Vehicle user settings --> Front Fog Lamp Dropout Enable On/Off --> Target Value = Deactivated
Turn Signals for DRL's
Maybe need:
ADAPTATION ---> DRL--> Day time running lights Configuration- Canada DRL
ADAPTATION
---> DRL - Day time running lights - settings --> DRL Lamp Location --> Turn Signal DRL
Disable Weather Alerts:
ADAPTATION
---> Radio user settings --> SDAR Travel Link Feature Present On/Off--> Target Value = Deactivated
Rescue119
Rescue119
Cory
Trenton, ON, Canada
@Rescue119
ADAPTATION
Maybe need:
ADAPTATION
ADAPTATION
Change my dlrs from the low beams to the halos, foglights on with high beams. And some other things
But now I just tested my remote start won't work. Any idea?
Rhinebeck01
Multiple places..
@Rescue119
What are "some other things' ?
Did you set-up the JSCAN disable ESS, hack with JSCAN?
Rescue119
Rescue119
Cory
Trenton, ON, Canada
@Rescue119
No I just checked ess is still enabled. Maybe sits the cable still plugged in. I'll try again tomorrow to dark and cold out.
Was just tire fill stuff which I don't have.
Rhinebeck01
Multiple places..
@Rescue119
Cable Adaptor for Chrysler 12+8 Programming Cable Connector, attached to the SGW should not be why your Remote Start is not working... Even with SGW connectors unplugged, remote start will work...
Not sure ..... but maybe if you left the Bluetooth Scanner plugged in that may be why remote start is a no go... Try with the Bluetooth Scanner unplugged and leave the Cable Adaptor for Chrysler 12+8 Programming Cable Connector, attached to the SGW .
Rescue119
Rescue119
Cory
Trenton, ON, Canada
@Rescue119
Everything else is working. I did a scan and no codes. I've read it has to do with the ess setting. Who knows maybe it will work in the morning lol.
Rhinebeck01
Multiple places..
@Rescue119
You probably have disabled the hood ajar plunger with JSCAN. Doing that disables Remote Start...
Read below... you need to go into JSCAN and enable that setting... the one that probably is set to disabled.... that is knocking out your Remote Start.
Jeep Wrangler JL Leaving Chrysler cable attached? ,,
Rescue119
Rescue119
Cory
Trenton, ON, Canada
@Rescue119
Where did u find that? I'll go see
Rescue119
Rescue119
Cory
Trenton, ON, Canada
Rhinebeck01
Multiple places..
@Rescue119
IF you ever have JSCAN related questions and concerns that you cannot find the ansers to here, you can communicate with representatives from JSCAN on their Facebook page.
You can Facebook Message them.....
https://www.facebook.com/obdjscan/
They are pretty responsive... their English is a bit lacking but what they do usually is...... walk you through your JSCAN related issue by sending you a custom video of them walking you through the JSCAN procedure you are trying to accomplish...
Oh, they are in a different time zone .... another part of the World so you may wait a few hours for a response from them.
Rescue119
Rescue119
Cory
Trenton, ON, Canada
Well
@Rescue119
The only.thing I have left to do really is change out the fender halogen lights to leds. Besides that the jscan has done its job.
