Leaks on inside back window of 2019 hardtop
Oscar16
Ohio
2019 Jeep Wrangler unlimited Sahara
Before everyone says it’s a Jeep it leaks. I have drove nothing but wranglers since 2000. I have had hardtops since 2015 never water roll down inside back window when it rains. Has sensors on inside window worried will ruin them. Little water part of a Jeep but sensor getting wet worries me. Anyone else have this problem month into your 2019 like me.
digitalbliss
North Alabama
2018 JLUR, 1979 CJ7
Take it into the dealer, I have had no leaks in my '18
TheBrandon
Brandon
KC
2019 Sting Gray Rubicon
Are you getting any rattling from that back window?
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
There was just another thread on this. I had a drip come in so i cleaned the gasket really well. Then used a silicone gasket cleaner / lubricant on it, coated and wiped it off a few times to get it really well. I have not noticed any more leakes coming in so far.
Some said when the doors shut the pressure pushes the rear window a bit causing a drip here and there.
dj3513
New Jersey
2019 JL Sahara Unlimited / Granite Crystal Metallic / Sky One–Touch Power Top
Curious if you have the One Touch roof?
Oscar16
Ohio
Oscar16
Ohio
Mine is drip too. I noticed when drops still on window after turned on wiper.
wrc777
Indianapolis
F250
Have you opened the back window when it is wet? If you do that water runs inside the window and when you close it runs down the window.
mlangs
Phila, PA
2019 JLUR Granite Crystal
I had the same issue with my 2019 JLUR. Take it to the dealer and have a water specialist look at it. They replaced the rubber molding around the rear (that’s attached the hardtop) and it’s perfect now.
Oscar16
Ohio
Thanks.
Kenc
Ken
Odessa, Florida
2020 RAM TRX, 2020 C8 Corvette, and a Wrangler 392
Boat Builder
I have the same issue and the dealer said it is common and they have a gasket kit on order for me. Happy to hear it works.
fightingmajor
St. Louis, MO
2018 JL Rubicon Unlimited Punk'n Orange
My 2018 does this as well. It's random. I can go through a powerful craws with it that's the pressure is so hard it damn near makes me def going through it and no water will get in. Let it sit out in the rain and water comes in there. Who knows. I'll have them look at it when I have to take my jeep in for something.
