Largest Tire on JLU Sahara - Stock Rims & no lift
YYCSahara
BDLL
Calgary AB Canada
2019 Jeep Wrangler Unlimited Sahara 2.0T
No, I mean biggest wheel you can fit without getting wheel spacers or offset wheels to prevent sidewall rub on full turns.
Ok cool, thanks. I'm trying to decide between 275/70R18 and 285/65R18 on stock Sahara wheels and no lift. I've read 285/70/18 might work as well but I haven't seen any pics of that yet. Seen pics of the first two sizes on stock Sahara.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
I have 275/70R18 but I have Rubicon suspension swap. So no, completely stock wouldn’t work.
offset_98
Tampa, FL
2019 JLU Sahara, 1993 Nissan 300ZX, 2015 Subaru Outback, 2011 Toyota Sienna
If I recall from doing this research, 275/70/18 will give you a lot larger tire selection than anything larger. Not saying there aren't larger but the selection starts to get limited.
offset_98
Tampa, FL
There are a few 275/70/18 Saharas running around with stock suspension and it does in fact work - I want to say I saw someone go 295/70/18 but I probably wouldn't go any bigger than what you did on stock suspension.
FWIW, I'm stock and will likely go 275/70/18 when the time comes.
slacker83
Peoria Il
2018 Sahara
At the tire place right now getting my new wheels and tires mounted. Went with black rhino barstows with 315/70/17, only mods are rubicon fender flares. We'll see how it goes....
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
if you stick with stock suspension you can always swap to rubi fenders for more clearance.
slacker83
Peoria Il
2018 Sahara
Didn't catch this thread was for stock wheels but regardless everything came out well and no rubbing.
StingGreyDoc
Josh
Michigan
2018 Unlimited Sport
That looks outstanding. I have been eyeing those wheels. Are they the 17x8 30 offset or the 17x9.5 -18 offset? Do you have a shot down the side to show how far the tires stick out?
slacker83
Peoria Il
2018 Sahara
These are the 17x9.5 -18 offset, Ill take a picture down the side. They do stick out but it isn't as bad as I expected. I much rather would have -12 offset or so to get them to tuck better.
faisal123
Faz
New York
2019 Wrangler Sahara & 2022 Wrangler Sport
Do you have any issues with the spare tire rubbing on the stock bumper?
Actually I didn’t change the spare tire. I just purchased a rigid spare tire cover and put that on instead which I think looks pretty decent. Btw I just ordered 285/75R18 Duratracs today and will get them installed in a few days.
wht18JLUS
Virginia
2018 Wrangler JLUS
I just put 285/65/18 BFG KO2’s E load on 18x9 ATX Lege Rims. The tires are considerably more aggressive looking than stock and no rubbing issues at all. I cannot tell the difference in ride quality so no downside there. Here’s a few pics for your research. Good luck!
This looks really good. No lift correct? Did you have to recalculate speedo? Does it look like you could you have went any bigger in tire size with no rub? THANKS MUCH
Roscop69
Ralph Patrone
2018 Jeep Wrangler JL Sahara
Installed 275/70R18 BFG K02's on my 2018 JLUS's stock 18"x7.5" rims. No rub, no spacing, no lift. Fit great. Anything in 18" rims is forced into load type E as a LT tire is required (Lite Truck) but the K02's don't feel much different from the stock duelers and they look awesome. No difference in noise, bit bouncier ride which is fine. Only issue is the speedometer is slightly off and could be recalibrated but dealers are saying that's like $300 so we'll see on that one. I've attached a chart to show the speedometer difference when upgrading to this size tire from stock. Thanks to everyone in this thread helping a newb out! Your input has been much appreciated.
That l
This looks great. going to do the same thing to mine soon. Like the the way it looks and doesnt sound like it changes the drive much.
mrbtd
Bill
Saint Johns FL
2018 Wrangler Sahara
Rubbing on the inside of the wheel well ? Really want to do a 305/70/18 on the stock wheel it is slightly taller and wider.
