Sold: Texas Lange Hoist a Top
coachcal
Aidan
Burnet, Texas
2021 Jeep Gladiator
Lange Hoist a Top for sale. In good condition. Located in Burnet, TX. I travel to Austin several days a week if that helps anyone.
Asking $250
Jeep Wrangler JL Lange Hoist a Top 20210910_180908
bgenesis12
Genesis
Avondale
2021 Wrangler 4 Door Diesel
I'm interested. Does this break down? I'm currently at Lackland for training. Will be leaving mid april and if it can fit in a CRV i'd take it back to AZ with me.
coachcal
Aidan
Burnet, Texas
2021 Jeep Gladiator
The base is 50" x 39" and you would have to disassemble quite a bit to break it down. The vertical pole is 62" tall and 52" inches out toward the arm. It is only two bolts to remove the pole and arm from the base. If those pieces fit in a CRV then it would ride just fine.
coachcal
Aidan
Burnet, Texas
2021 Jeep Gladiator
Actually, it looks like that base is just square tubing attached with bolts and lock nuts so it could come apart as well if you wanted. The vertical pole and arm could be detached or the arm could be loosened and folded down along the vertical pole. The more that I look at it, it would definitely fit if you don't mind a little disassembly.
