Lack the strength to mount tires
lightsout
Gary
Seattle
I use a mechanics Creeper from Harbor Freight $34 it hold the tires perfectly I then jack the car to align and since it moves in all directions tires go on effortlless, plus it is a great creeper I used for installing my lift and doing periodic inspection and re-torqueing. Used for 33's-37's works great. For the spare just have someone a little younger do the heavy lift.
https://www.harborfreight.com/40-in-300-lb-capacity-low-profile-creeper-gray-63371.html
As you can see it has a perfect dip that cradles the tire so the tire stands on its own.
whiteglad
Vegas
2020 Gladiator
A shovel or pry bar works for me to lift the tire enough to get it onto the lugs.
FINN 2.0
Larry
Carbonado, Wa
2021 JLUR. 1979 Ford 150.
I have been using a wheel dolly with built in jack from Harbor Freight. For the spare tire I just put it on a chair and push it on to the mounting studs.
rickinAZ
Rick
Phoenix
2021 Rubicon Diesel
I have the same creeper - good tip. My “someone a little younger” encourages me to go to Discount Tire. :)
hoag4147
Rick
DFW, Texas
2018 JLU Sport S / GMC 1500AT 4x4
I think I'm going to make up something like this for my spare. Great idea. Thanks for the inspiration.
Still need to eat your wheaties with those bead locks and 40s ;)
WorkingMan
Tim
Arkansas
2019 Jeep Wrangler Sport S
Any DIY ideas with respect to rotating the spare off/on? I do the seated method, with my ankles doing the lifting, but that only works on the four wheels.
Get one of these at Harbor Freight
Fastmover
Bob
Ottawa
2019 2.0L Billet JLR: Ordered 1/9. Delivered 2/13. Picked up 3/5.
I like the simplicity of your solution. Has that bolt screwed into the ceiling stud given you any trouble?
None what so ever. It's screwed into a truss 2x4 which can easily handle an extra 100 lbs. for a few minutes.
huberro2
Ron
Fountain Valley CA
JL Rubicon 2019
Engineer
Poor mans solution: To mount on to the wheel lug bolts, use a block of wood and rotating the tire to align with lugs bolts. As you roll the tire towards the block of wood, it starts to rise up (power of levers), to the appropriate height. and clear the ground, then push on to the lug bolts. Sometimes it takes a few rotation tries, but it is a back saver. As far as the spare, I use a short step ladder to rest the tire on before popping the tire on the rack mount. Daily gym workouts a plus too.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
I can’t take credit because someone else mentioned it earlier in the thread.
Most of us own a High Lift Jack. That should be great for the spare.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Question for those of you who have a spare but can't lift it without a mechanical advantage that you are unlikely to have when away from home.
Why do you have a spare?
Absolutely being serious here. If you can't change your tire when you are out and about, what good is that tire hanging from the tailgate? You would be better off getting rid of the weight, and keeping an air compressor and plug kit with your Jeep.
Poordad
Marc
Santa Clarita, Ca
2013 Acura TSX
If you are off road and get a flat that does not damage your sidewall, if you are able to plug your tire, you won't have to change your tire. Just need a plug kit and a way to fill the tire.
Diode Dynamics
