Labor Hours for Tie Rod, Drag Link, Track Bar.....install
vinniechin
Vinnie
Northern NJ
2020 JLUR
Hey guys.
How long should it take to install Tie Rod, Drag Link, Track Bar and Track Bar/Sector Shaft Brace?
Just wanted to budget my time. While there I'm going to do geometry correction brackets.
Any estimate would be helpful so that I can plan meal and beer breaks for the buddy that's going to help me out. He is the tech, I'm the tool passer.
Thanks in advance and appreciate any insight.
Vin
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
maybe 3 hours to get everything bolted on and home garage alignment its all pretty easy tasks, but that time does not factor in shit talking and beer/pizza consumption
MarkY3130
Denver
2019 JLUR
With two people Iā€™d say three hours is about right. Took me around 4 by myself.
If you want to do some ā€˜pre workā€™ to cut some time out, you could unbox and assemble everything, measure yourself the current Tie rod length and set the new one to same length, etc. These steps anyone can do and they do eat up time.
vinniechin
Vinnie
Northern NJ
2020 JLUR
LOL Thanks and there will be plenty of that.
vinniechin
Vinnie
Northern NJ
2020 JLUR
Thanks. I don't know how you guys can do this so quick. I'm learning and want to understand the science behind which is why I want to do it myself. With these estimates I will double the time as a normal learning experience.
These estimates include the geometry brackets and sector brace? Geez...I'm getting hopeful I can get it done in a day or two then.
Thanks for the replies.
Vin
MarkY3130
Denver
2019 JLUR
Vin
Sorry, I didnā€™t account for the geometry correction brackets, I should have stated that. I have never done that so wouldnā€™t know. But Iā€™d guess an hour or two for that.
I did include the sector shaft brace, I did do that.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
Spend the money and get adj control arms either lower or upper vs the relo brackets. Sector shaft brace needs a big socket. Canā€™t remeber off the top of my head, itā€™s in the tool box. Tie rod isnā€™t as quick as a direct swap since youā€™ll need to address the steering stabilizer relocation solution. 3hrs isnā€™t far off, just depends how fluid yā€™all are and efficient
Brett
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Spend the money and get adj control arms either lower or upper vs the relo brackets. Sector shaft brace needs a big socket. Canā€™t remeber off the top of my head, itā€™s in the tool box. Tie rod isnā€™t as quick as a direct swap since youā€™ll need to address the steering stabilizer relocation solution. 3hrs is far off, just depends how fluid yā€™all are and efficient
Brett
Will need a 42mm for that nut
vinniechin
Vinnie
Northern NJ
2020 JLUR
Brett
Thanks so much for the feedbak. Doing the geometry correction brackets because the Jeep has the Mopar arms already and the brackets were given to me from a friend that went with adjustable arms. I couldn't beat the price!
vinniechin
Vinnie
Northern NJ
2020 JLUR
Brett
I'm using Yeti track bar, drag link and tie rod. Using synergy steering stabilizer relocation brackets on a new Fox steering stabilizer. Really appreciate everyone's insights. This is why the community is so great.
Vinnie
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
Track bar is super easy, just two bolts, one on frame, one on axle.
Drag link is tricky, you have to buy or borrow a fork separator (don't know the exact name) to undo it from pit man arm.
quietpeen
Chambersburg, PA
2019 JLUR
You are thinking of a pickle fork
And Iā€™m going to add to this that the hardest part will most likely be getting the ball joint out of the pitman arm. Start soaking it now with WD-40
Roky
Roky
Hey guys.
Vin
When you go at the drag link with the pickle fork, hit it a few licks, and then reposition and hit a few licks, work your way around as far as you can and still have a swing. Itā€™s a crap shoot, Iā€™ve heard some falling off with the first lick , and Iā€™ve heard of some taking over an hour.............
good luck brother.
vinniechin
Vinnie
Northern NJ
2020 JLUR
good luck brother.
Thanks all...sounds like its definitely gonna be more than 3-4 hours for me
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Hey guys.
Vin
3 hours. The only thing that can slow you down is the pitman arm TRE. Make sure you have the right pickle fork and get it undone first - as it will determine the time for the rest of the project.
