KIWI Master 9" JL LED LIghts
JSFoster75
Bluff City, TN
Thanks, maybe with will help stop from driving around with my hand on the hi-beam switch waiting to flash the next car back after they flash me...... Sooner or later I'm going to do this to a cop, that's not going to make him too happy.
On a stock height Jeep, you should not need to adjust them, but if you have a lift, definitely need to aim them as suggested above.
emilboya
Emil
TX
Hummer H3 (Sold) & Jeep JL
Process Engineer
Made a new thread about this but realized I should have just added it here.
Any idea what this could be? Had my KIWI headlights for about a year and about a month ago I started getting these weird marks on the outside of the heads lights. Any suggestions? I love these headlights and want to find a way to salvage them
jludave
The Isle of Long
IT Manager
Any suggestions?
Posted this in your other thread.
Try a clay bar to see if it will remove that. It almost looks like some type of overspray.
emilboya
Emil
TX
Process Engineer
Posted this in you other thread.
I'll try that! Thank you
JSFoster75
Bluff City, TN
Jeep Wrangler JL KIWI Master 9" JL LED LIghts F4D03B4B-94D2-44F2-8CC5-3FD3A04415D0
Is it pitting from sand maybe??
FrankieGee
Georgia
2021 willys 2dr
i’ve had static since I put in my a-pillar lights, as best I can recall, the LED headlights did not affect my static noise. I think it’s because the wires are running too close to the antenna in my situation. I’m going to go to a wireless solution.
Bought jeep 2 weeks ago new and installed kiwi's
I've basically lost fm radio reception due to static.....when I turn on my Kiwi's
Also battery voltage drops to 12.6v while accelerating or maintaining a constant speed, when I let off the fuel or brake volts jump to 14.5v
(while headlights on or off)
Did you isolate your radio reception problem or was it a bad set of kiwi's?
JSFoster75
Bluff City, TN
The main issue I found that caused radio static was because I grounded to the frame and/or inner metal fender instead of directly to the negative terminal on the battery. The isolators did nothing to help in my case.
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Your voltage is completely normal, that’s just how the charging system works.
IDK about the static, I have no static.
Gregj
