MacBigButt
- Martin
- Jan 25, 2018
- BC, Canada
- Nissan Leaf, 2018 JL Unlimited Sahara
- Vehicle Showcase
- 1
Good questions and to ease your concerns, my EVO Stage 3 lift is arriving "EoD Tuesday" according to Fedex. I won't be off-roading again until the lift is on.Did you change springs? If not, did you check your springs at full droop? 3" is probably too much droop to add to stock springs. Did you add bump stops to protect the longer shocks at full compression? Expensive shock to not have proper bump stops.
That said according to King specifications, these shocks are intended for 0"-2" lift, so assuming they know what they are doing, there is no problem using these on a stock suspension with regards to bottoming out.
The springs were still under compression with the shocks at full extension so I don't foresee any issues there either. At least as long as the sway bar is connected.
