Key fob not detected
Bowhunter23
Ohio
'22 JLUR-4xe, '85 CJ-7
I’m getting this intermittent issue where my ‘18 JLU Sport won’t detect my key fob. Fob won’t unlock the doors (don’t get the red light on the fob like when it works). Have to use the manual key to unlock then it sets off my alarm and I have to press the fob to the start button to start the engine. Not a fob battery issue. Happens with both fobs and one fob has a brand new battery.
I noticed sometimes I get the red dash light flashing which I believe is the security light.
I heard there is a fuse that you can pull and replace after 30 or so seconds that resets this.
Thinking it was a security issue I pulled F05 Security Gateway fuse but that didn’t work.
Is there a different fuse I should try? Or is this a bad RF module and trip to the dealership?
thanks.
Multiple places..
thanks.
@Bowhunter23
The F05 fuse in the PDC, is for the "Security Gateway" and that has nothing to do with such an issue... the issue you are having..
It is a good practice though to routinely push down any and all in the Power Distribution Center (PDC) as just that wards off some electrical Gremlins.
You may have read, about JL owner's pulling F97 which, causes UConnect to immediately reboot. This is helpful with many UConnect related issues...
IF you were saying your Proximity was out, etc., I would say try an F97 fuse pull as UConnect deals with Proximity on/off as it has settings for same.
Curious.... when did this issue of yours star?.... has it just been since colder Weather has set in?
You mentioned one fob has a brand new battery and the other does not..... Can tell you that many/most posts here over the last 3 yrs. talking the issue you are having...... were fob battery related.. Guys/Gals, THINK their fob battery is aok and it is not.. Consider buying two, quality CR2450 batteries and putting them in your fobs.... then see if the issue still happens with one or both fobs.
Yes, could be a bad module.... but exhaust all the simple remedies first before that dealer visit... ...
...UNLESS, if you are still under warranty.... if so get to dealer ASAP for this, as your 2018 will soon soon be out of warranty...
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I had this problem once….replaced FOB batteries and pressed fuses. Was fixed after I disconnected the battery and reattached. No problems for the last year….
Rufus
NYC
2018 2 door JL Sport 3.6 V6
I just had this problem this morning on my 18 Sport. Same key fob I’ve been using since I got it brand new. I haven’t used the spare. It took me two tries of pressing the start button with the key fob to get it started. I just figured that with the key fob battery being over 3 years old maybe it’s dying?
FYI no proximity sensor or even electric locks. I rarely even remove the fob from the vehicle.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Replace your fob battery. By leaving it in vehicle it is most likely "chatting" with the jeep constantly.
Rufus
NYC
Good suggestion, thanks. I’m going in for my 20k service in the next couple of weeks anyway so I’ll have it done then and if it gets worse in the meantime I’ll use the spare.
BTW is the battery replacement user serviceable?
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
I'd get it in and have the module for the keyless system scanned. Sounds like the problem is with the vehicle and not the FOB. Even with a cheap new battery, it should work. I've seen people replace their batteries a number of times and come to find out it's not the FOB but the module. As a default, I recommend people just go to a hardware store, buy a 5 pack of the model battery and replace both FOBs at the same time. Keep the rest for next time.
When it comes to batteries, my VW tells you in advance to replace the battery. No matter what super duper best battery ever made with a 5000 star rating on every forum and shopping site along with detailed YT videos of the best of the best, they only go maybe a year on a battery. Makes no difference if you place the FOB 2000 miles away or keep it in the car. Thus like in my advice above, both get replaced at the same time, once that warning comes up.
Dyolfknip74
2021 JLU Rubicon
Yes, you can replace you're own battery. Pretty sure it's a CR2450 flat battery, although mine is a 21 and I haven't broken it down.
*Edited for correction.
Multiple places..
Yes, you can replace you're own battery. Pretty sure it's a 2032 flat battery, although mine is a 21 and I haven't broken it down.
@Rufus
@Dyolfknip74
@abnormal4x4
Fob battery for any and all stock JL/JT fob is a CR2450 ......
....and it is very easy to get out of the fob and to place a new one in the fob.
Dyolfknip74
2021 JLU Rubicon
@Rufus
@Dyolfknip74
Watch first couple of minutes of the video at the link below and you will see how to access / deal with the battery in a stock JL/JT fob..
https://vod-progressive.akamaized.net/exp=1637776611~acl=/vimeo-prod-skyfire-std-us/01/879/21/529395389/2492239882.mp4~hmac=19421dd4533341773fe70f5e9cccb6a66a14a54cd5253087db5c40b299c2da4d/vimeo-prod-skyfire-std-us/01/879/21/529395389/2492239882.mp4?filename=Factory+Fob+Disassembly.mp4.mp4
I knew any mention of the fob would summon you. ;)
Thanks for clarification.
Rufus
NYC
@Rufus
@Dyolfknip74
@abnormal4x4
Watch first couple of minutes of the video here and you will see how to access / deal with the battery in a stock JL/JT fob..
That is so helpful thank you so much.
Multiple places..
@Rufus
Suggest you buy a 2 pack of quality (not cheapo's) CR2450 batteries and change the battery in both of your fobs, not just the battery in the one fob.
Rufus
NYC
@Rufus
That’s exactly what I was thinking since they are 3+ years old. Thanks.
ca.sowers21
PA
2018 Wrangler JLU
Having this same issue, only since the weather has changed and has gotten colder. I keep the fob in the Jeep in the garage, so it's cold now. The difference I seem to be having is that the remote works, it just isn't recognized by the Jeep. Sitting inside the car, I can remote start it. I can remote start from distance. I can lock/unlock like normal. I just can't push button start with the fob in the car. Once I use the fob to push the button, Jeep starts and after I drive for a bit all seems ok, until I try to start it again. I'll try new batteries to see if that helps.
Multiple places..
@ca.sowers21
Not good to do... a mistake..... not wise at al ....... keeping your fob in the JL, all the time...
Do research on this so you understand why.. If you do this keep the fob in a Faraday bag in the JL.
For fob batteries, buy fresh, quality batteries and replace the battery in each fob..
