KnG818
When pushing the button with the fob doesn't work, the display shows a picture of the owner with his head up his ass.
Indeed it does!i'm glad to be a cheap a$$ because it pays off in the long run.
Mine just said something like, "Key Fob not detected inside vehicle." Or something like that.What was the warning sign that the battery was dying? (So we know.)
Even on the screen it shows a pic of the fob pusheg against the start button.
Did they need both fobs, to reset the Firmware?? I guess I will bring it up when I take it in for a free oil change. Thanks for the helpful info.the key fob not detected message isn't dead battery its a Firmware update. now before you say changing the battery worked and yes it will but only for a few months and why i say this my mother has a Fiat 500x and it had the same problem. i changed the battery in the fob twice within 2 months because it kept on dieing the 3rd time it went out i went down the dealership for oil change taking now my dead fob with me and found out it was the fob not the battery it needed a firmware update. now 1 year later it has no problems. also if you keep your fobs close to the car it will drain them faster. because the car keeps on pinging the fob over and over again. so take the fob to the dealer and see if there is a firmware update for your car. and on a side note they lost one of my fob for my jeep before i took delivery of it and just last week they found it so now i have 3 fobs.
I don't think it works that way. I believe the vehicle transmits a very local signal to ping the FOB smart chip. When the smart chip receives the ping, it activates a reply signal with the encrypted code to allow starting when you push the button.Of course you have a battery. It's always broadcasting a signal. This is how you are able to start the engine.
