Combat Chuck
- Chuck
- Dec 12, 2018
- Motor City Detroit
- Sarge Green JL Willys
Just installed the Kentrol door hinge delrin bushings, stainless guide pins and I made some rubber caps for the guide pins. Install was a snap, and the guide pins are a must for anyone going doorless. The stock door hinge bushing liners are easy to remove. I followed the official Kentrol video on YouTube. Make sure to crush and knock them out from the top on JLs as the video demonstrates. The stocker liners have a flange on the bottom that prevents the removal from the bottom like you normally would on a JK. I used some masking tape around the hinge in case I accidentally slipped with the screwdriver and/or hammer.
Also here is the video on the guide pins installation as well.
I lubed the Kentrol liners inner and outer with some Fluid Film for both lubrication and corrosion resistance.
I leave the Kentrol guide pins attached on my Jeep year round since they are T304 stainless. I didn’t care for the look of the silver guide pins on my blacked out Willys, so I made some removable black rubber caps for them just for aesthetics. The rubber caps were 3mm too long for the upper hinge pin guide, and 8mm too long for the lower hinge pin guide. I trimmed them with a sharp exacto blade. Turned out awesome.
Kentrol Liners: https://www.quadratec.com/p/kentrol/door-hinge-liners-jeep-wrangler-jl-4-door-unlimited
Kentrol Guide Pins: https://www.quadratec.com/p/kentrol/door-alignment-pins-jeep-wrangler-jl
SBD Rubber Caps:
https://www.amazon.com/dp/B07BVCBS71?
SBD Rubber Caps:
