Jeep Generation
- Kevin
- May 12, 2018
- San Dimas CA
- Website
- www.youtube.com
- 2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Hi @Dano36For long range trail driving : the 6" Gravity Sport LED or the 6" 100 SlimLite LED
Which is brighter and has longer range?
KC’s LED Slimlites use high-performance Cree XD-16 LEDs. They have an optimized beam pattern that has a spot beam output for long-distance lighting along with fill light for short to mid-range light. If you want the brighter with the longer distance, go with the Slimlite LEDs, plus you get some of the closer range light. Here are some stats listed below you can check out also. You can use KC Promo Code KCJEEPGEN on their website right now for 10% off.
LIGHT PERFORMANCE (per light at 12V)
SLIMLITE® LED 6”
- Raw Lumens: 7,260 lm
- Lux @ 10 Meters: 2500 lx
- Candela: 250,000 cd
Pro-Sport with Gravity® LED G6 - Spot
-Raw Lumens: 2,300 lm
-Lux @ 10 Meters: Spot- 2150 lx
-Candela: Spot- 215,000 cd,
SPECIFICATIONS (per light)
SLIMLITE® LED 6”
- Wattage: 44W at 12V; 50W at 13.5V
- Amp Draw: 4.0A (at 12V)
- Voltage: 9-32V
- Color Temperature: 5000K
- Dimensions: W - 6.21" x H - 6.71" x D - 2.70"
- Housing: Black UV treated aluminum housing
-Wattage: 20W
-Amp Draw: 1.63A
-Voltage: 9V-32V
-Product Dimensions: W - 6.25" x H - 7.00" x D - 4.54"
-Housing: Black Composite Polymax housing
