KC HiLites - Pictures / Videos Post Here!
Pointnshoot
Chip
Denver, CO
Jeep JLUR
[/QUOTE
When you wired, from your diagram it looks like you got rid of the direct to battery connections and the KC Relay provided with the kit and are drawing power directly from the Aux Switch (knowing there is a relay behind that as well) is that correct? KC seemed to want their relay in the system but that seemed redundant to me. I got my relays from Amazon today and will probably tackle the wiring connections next weekend.
Jeep Generation
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Jeep Wrangler JL KC HiLites - Pictures / Videos Post Here! 1600188985604
Jeep Wrangler JL KC HiLites - Pictures / Videos Post Here! 1600189013182
You can also use a Fuse Tap to tie in to your Acc/Run circuit.
Jeep Generation
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
2018 Jeep Wrangler JLU
Traveler
So my FE3 lights are installed. I have the combo pattern and installed them on my A-pillar. These lights are crazy bright and they look really nice. I have an 8 x switch panel and hooked the backlit to one switch and the white light to another. I just have to make sure I remember to turn the backlit off before using the white light-it's shouldn't be an issue.
The only criticism I have is that the wire coming out of the light to the connectors is too short... the connection sits outside next to the light for all to see. I wished it was longer so I could have tucked it in under the side panel where the bracket is. It's too conspicuous... and also, totally exposed to the elements... Hopefully they will fix this in future reiteration of the light.
Other than that one criticism, it's really nicely made piece of equipment. Money well spent.
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Network/Systems Engineer
i noticed that as well. the dual flex and other iterations of the older flex lights were not that short... In time I am going to add another 16 inches to that harness, its way too short.
Pointnshoot
Chip
Denver, CO
Jeep JLUR
I noticed that too.... the connector sits right behind the light before the wire runs under the cowling. Gray plug stands out like a sore thumb. Trying to figure out a way to hide the gray.
WTFSoCal
Mission Viejo, CA
www.youtube.com
JLU 2018 Rubicon
Jeep Wrangler JL KC HiLites - Pictures / Videos Post Here! 62161891259__518DD813-8228-493C-824C-E358EBD0BA1E
Like that HAM antenna mount !
CalPolyDM
Doug
Cincinnati
2020 Jeep Wrangler 2 Door
Last night I installed the gravity pro 6 on the A pillar and the front bumper. The big issue... KC really need to extend the plug a few inches, it‘s outside the pillar and really sticks out and looks bad. If these plugs were a bit longer you could hide them under the cover.
I also installed two cyclone lights to help with reverse, not sure about it yet... but for the moment it’s function over pretty.
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
Traveler
Here are my FE3s - I zip tied the connector behind the light and so it looks less conspicuous but then, the cover came undone... So am wondering if that's an issue and so I should untie and cover the wires again or leave it as is... For the price and the reputation of KC lights you would really not expect this... I didn't. Anyhow... I am sure they will fix it in the future.
Onward4x4
Nima
Chicago, Illinois
www.onward4x4.com
Traveler
Looks Great man!
Looks like the zip tie might be pressing in the tab to disconnect the connectors. so that would have been the cause of that.
Thanks. For sure those lights looks nice! And they are functional. I think I may get rid of the zip ties.... I'll think of something else at some point...!
