JeepAustinWeird
Austin, Texas
2018 JLU Rubicon
Hello Steve,
Here is a post written by @Jeep Generation under this thread link below explaining wiring the FE4 to stock Mopar Aux Switches...
https://www.jlwranglerforums.com/fo...a-4-wiring-to-aux-switches.66289/post-1414344
Here are some pictures of the KC harness and info on the Mopar Switches with Fuse locations.
The 2 legs going to the actual FE4 lights each have 3 wires in them. Red, Black and White.
The Blacks need to go to your battery negative for best connection.
The Whites are the Amber back light. If you want to use a AUX Switch, I would recommend Switch #3 or #4. They are 15 amps max. To match the KC wiring, you should swap out that 15 amp Micro Fuse for a 3 amp to match what they are using to safe off that wire to the light. They want it to pop at 3 amps, not 15.
The Reds are the Main White Light. I would recommend to use with Switch #1 or #2 as they are rated at 40 amps max. Now I would recommend swapping out the 40 amp Cartridge Fuse for a 25 amp to match the KC wiring. They want it to pop at 25, not 40. By the time it reaches 40 amps, something could burn up. If it is hard to find the Cartridge Fuse (not a common fuse), you would also use the KC 25 amp inline fuse between the Mopar Switch leg and the KC Red wires.
Note that KC did not intend for both White and Amber to be on at the same time. So make sure to turn off the Amber before turning on the White. "
Also, here is a video showing some night time footage...
Hope this helps. Let me know if I can help with anything else.
Thanks for that. Great write up and video. Very useful information and explanation.
track.n.trail
Owen
San Francisco
2020 JLUR
Software Engineer
Volstock
Bob
Tennessee
2021 Jeep Wrangler Sport Altitude
Info Sec
Welcome to the forums. As my wife already knows when I add lights they will be KC.
ralphgb
Ralph
Central Massachusetts
2018 Jeep Wrangler Sahara Unlimited JL
@KC HiLiTES Can you offer an option for the amber light covers on Gravity Pro6 model with the KC logo on it? I think this quick edit job looks bada$$. Rock Guards would also be nice to show your KC Hilites love but isnt available for the Pro6 model!
You could do this yourself with something from @pixeldecals
pixeldecals
Rock Sponsor (Level 1)
Chicago Area, IL
www.pixeldecals.com
2018 Sting Gray JLU Rubicon, 2013 JKU Rubicon
I've considered this but I want to be able to still use the lights and these lights would probably melt the vinyl. I was thinking more translucent with no lighting lost.
We could try cutting some from the material used to smoke headlights
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
I've got the Gravity Pro6 lights. @KC HiLiTES Do you have the open-air (shine-through, or whatever they are called) covers available for these?
I think you are referring to the Rock Guard covers on the SlimLites in the above picture from @track.n.trail . We don't offer those covers for the Pro6 lights, sorry. Here are the 3 covers that we have for the Pro6 series...
Pro6 Covers
KC HiLiTES
KC HiLiTES
Kevin
Williams, AZ
Thank you! If you have any questions when you are ready for some lights, let me know.
Jim Marsh Chrysler Jeep
