SH556JL
Steven
Florida/Georgia
21 JLR M6 RIP, 23 JLR M6
WOW! looks awesome! I've searched around here as well as youtube, but couldn't find much installation details for our JL. Do you have any particular helpful resources? Mind sharing?
Seems everyone recommends a good hogring plier, there are so many choices on Amazon and I have no idea what would be good/helpful for this project. Would the bended one at 45 degree make this job easier?
Also any tips on removing that center console to install the switches?
Thanks you SO much!
Any of the red handle ones will work, itā€™s basically standard issue. I done way more seats then I care to admit to with them. The bent 45 degree pictured above, at that angle seems more annoying to me then anything. I recommend sticking with standard galvanized hog rings and a good set of dykes. If this is your first installation, you may not get the depth evenly at the seems and will need to cut the hog rings. Stainless steel would need to bend them to be removed.
If you want the Snap On of hog ring pliers, look into C.S. Osborne. But it isnā€™t needed for a one off job. I also like to sit the skins out in the hot sun before install.
zyt
Maryland
Mazda Miata
The center console is fairly easy to remove, there are only a few bolts and the whole thing lifts out. When I did mind, I removed the seats first doing the leather, then did the console for the heated seat wiring which was easier, then reinstalled the seats. Youā€™ll need to loosen the shifter boot too.
The smallest hog ring plier is the best, makes getting into small spaces easier. One trick - if youā€™re having a hard time getting a tight fit in an area, grab a zip tie, cinch it down, then use the hog ring. Also, start with the center of the seat first, then work outward.
Also, if you have a steamer, you can use this to ease install with the leather as this softens it a bit. Absent a steamer, put a tiny bit of hot water on a towel and rub the leather.
Super helpful. Thank you so much. Your post gives me a lot of confidence to do this project myself. How did you wire up the power and ground for the heated seat?
Whaler27
Alex
Oregon
Saving the world :-)
Anyone have these installed?
I have the Katzkin leather in my Jeep. Itā€™s my fifth set of Katzkin, but the first set in a Jeep. I replaced the worn leather in one super duty truck, one Ram truck, one Tundra, and my wifeā€™s like new 2005 mustang GT (after I sat in her driverā€™s seat with a screwdriver in my back pocketā€¦) :facepalm:
Iā€˜m not fond of the quilted look, so I never ordered that. I also passed on the perforated leather, because the seats are virtually impossible to clean if you ever spill a drink and the liquid moves into the pores. Ask me how I know. :facepalm:
zyt
Maryland
Mazda Miata
Thank you for the feedback. I want to make sure I have proper tools before taking my seats out :)
I will be sure to pay extra attention at the seems and most importantly take my time.
CalPolyDM
Doug
Cincinnati
2020 Jeep Wrangler 2 Door
Canā€™t remember if I ran the ground to the factory ground under the console or back to the blue sea box by the battery, youā€™ll have to look to see if they want it to the battery or chassis. The pic below is from when I installed the dynamite and subs, but you can see the factory ground below the e-brake. The power was run to my block up by the battery. I used to be into boating, decided to use a marine fuse block from blue sea systems for my additional power connections.
zyt
Maryland
Mazda Miata
I got all 5 headrests done last week and completed the 40% rear seat today. It really wasn't that bad. Patience is the key and also have a clear expectation that it will be a time consuming project. I don't want to do everything in one day, so I am purposely spreading this across multiple weeks and work on it whenever I have a couple hours of free time.
Jeep Wrangler JL Katzkin Leather Seats Review by TrailRecon 847280FA-7ADA-473D-9E30-C89037C56D79
Jeep Wrangler JL Katzkin Leather Seats Review by TrailRecon 8820F298-6D53-4717-8295-3900E6C61CBE
Jeep Wrangler JL Katzkin Leather Seats Review by TrailRecon 444E347E-3AB1-4016-AD75-21184C42F259
Now need to work on some wrinkles on the side.
The seat release cover gave me a lot issues, I end up broking 2 clips but still couldn't get the last one out. I managed to work around it. Let's how long it would hold out. Anyone has suggestions on how to properly remove it?
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
You do realize those fuse blocks are rated at 100A max for all circuits, and that input cable appears sized to carry far more than that?
TheRaven
Reading, Pennsylvania
2021 JLU 80th
Electrical, Mechanical, and Aerospace Engineering.
There's no problem with that. Blocks should be sized for max draw, not max rating. Just like the breaker panel in your house - it's probably rated for 200A, but if you sum up the total ratings of all the breakers currently in use, you'll get a number closer to 400A.
A lot of circuits in 12V auto applications draw less than an amp, but will still be wired and fused for 5A...so you could have four circuits with a summed rating of 20A that actually draw a total of 0.8A.
Coolbaldguy
Tim
TN
2019 JLR
Can anyone comment on the comfort of the seat covers? I have a 2019 Rubicon 2 door and the factory cloth seats with heat. The factory seats are not soft enough for my liking, and the lack of lumbar support on the passenger side makes my DW not want to go on long rides. I realize comfort is subjective and everyone is shaped differently, but have any of you done this upgrade strictly for the comfort factor? One last question, how do these covers affect the side impact air bad located in the backrest?
Genedarrell
Gene
Ks
2021 JLU RUBICON
Iā€™ve installed quite a few kits for customers and dealers. Never had any issues at all. Fit is as good or better than I can custom sew. They computer cut all their materials exactly so itā€™s very precise.
I called the local dealer and asked about getting the mopar katskinz for my rubi. He told me that I had to have leather seats for the seat covers to fit right? So you have to have leather seats to buy leather seat covers? Didnt make sense. Does that sound right to you? Thought I would as as you have installed these.
Rockstar08
2017 Jeep Wrangler Unlimited Sport
Hilarious your dealer is an absolute idiot and doesnā€™t have a clue what he is talking about, please do not take your Jeep there for anything ever!!
oyealiz
Liz
Denison, TX
Solar Yellow TJ and Sting Gray JLU
I just finished my seats, done them myself. Years ago I use to be an authorized installer and did upholstery, including sewing. I feel their overall fitment has greatly improved since I last done them regularly. But feel they still donā€™t do enough quality control as I seen some flaws that shouldnā€™t make it out, but I can live with itā€¦ Itā€™s overall very good quality for production work and most wouldnā€™t notice the issues unless I was to point them out.
My Jeep is a 2021 Rubicon 2 door and itā€™s by far the easiest install Iā€™ve ever done. These seats are pretty simple and straightforward.
Which one of the Katzkin reds is this? Thanks!
GMX
AZ
2024 Sahara 2.0
I just chatted with Katzkin re heated and cooled seats for a 2024 JL Rubicon.
They said "We may not be able to add in the cooling unit due to the sensor for airbag in seats".
That is disappointing.
So I am thinking of ordering a 2024 JL with cloth seats and the Cold Weather Group in order to get the heated seats and steering wheel and then have non-heated Katzkins installed.
When I asked about saving the new original cloth seats, they said the installer cuts them up to remove them! That does not make sense to me as they would probably damage the underlying foam cushions or heater units.
Maybe I'll remove the cloth coverings myself before Katzkins does the install.
I think I could probably sell the brand new seat covers to help with the cost of the new leather, or install them myself on a jeep project build.
Has anyone done it this way?
