“Pebbles”, 2020 JLU Granite Crystal build
Sparticat
Madeira Beach, FL
2020 JLU
Starting a thread to document mods to my new 2020 JLU Granite Crystal Recon "Pebbles”. I am not much of a gear head, so starting with a few easy security and camping mods that will be useful for some upcoming travel and in daily driving...
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Springtail Solutions tailgate table is up first. After a bit of research on different tables I ended up here as I wanted the Molle panel on the back.
This was an easy install taking about an hour and half.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0066
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0067
Prepping the plastic panel for the standoffs.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0069
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0070
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0071
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0072
Ready to attach the worksurface...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0073
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0074
And Molle bags...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0075
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0076
I am very happy with it. No rattling while driving, a usable work surface while camping and some much needed extra storage for first aid kit and cooking supplies.
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Next up, Diabolical Slipstream security enclosure for JLU soft top. I did a fair amount of research and this seemed to be the best option out of the few I was able to find. The main criteria were:
  • Secure items in the vehicle when the soft top is down, doors off (this is a soft top only vehicle)
  • Maximize the amount of space available in the cargo area
  • Flexibility to open the top to fit larger items
  • Flexibility to remove top and back and have the full open space inside the vehicle with the rear seats folded down
Parts all laid out... they arrived very well packed...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0077
First step was to remove the folding, carpeted flap behind the rear seats as the seat bolts are on both outside edges are utilized during the install...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0079
The first of the seat bolts used on the passenger side...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0078
Easily to follow instructions as the various sections went together...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0080
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0081
Some of the spaces were pretty tight for chubby fingers to get the nylon nuts in place...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0082
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0083
There is a small access door that you can unlock to get underneath the rear portion with the seat folded down if needed. Personally I don't see myself using this much, but you never know...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0084
Overall pretty happy with how it turned out. First vehicle I have ever had where I was happy to install my own trunk! :like:
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0087
I have some t-handles on order. The kit does not come with them and since I got the JLU with a factory soft top I did not have them either. This will provide some additional tie down points above and beyond those integrated into the rails alongside the hinged top panels. I will probably install some cargo netting behind the rear seats and some anti slip material on top so that I can stack up containers for additional storage on the top for longer overlanding trips.
The top section on the unit fits under the lip of the tailgate so as long as the tailgate is locked the top cannot be accessed unless you were very determined and had the appropriate tools. I see this more as a way to prevent the casual passerby from snatching something just because it is visible.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0088
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Some interior stuff: Rugged Ridge paracord grab handles, Mopar rubber floor mats, Tuffy center console security box, Auovo cup holder coasters, Tazer Mini JL.
Knocking a few odds and ends off the checklist...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0094
Had to flip these in order for the install to work on all 4 with the soft top mounting points over the rear doors.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0095
The carpets were full of sand on day 1 so I knew they had to go right away. Had Weathertech mats in a previous vehicle but decided to try the Mopar ones here for the drain holes and red Jeep logo.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0096
Not much to show on this install as it was pretty simple. You lose a bit of space but I like having the option to more securely store some protection as needed if not carrying concealed.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0097
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0098
Why not? :)
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0099
The Tazer was relatively easy to install and get setup. You need to be a bit of a contortionist to get up under the dash. I did not need to take off the piece under the steering wheel as I have seen some others do. Primarily wanted this to disable ESS, set the TPMS warning level and get the correct splash screen on the dash! Seems like a silly thing, but how does a vehicle this expense arrive from the dealer with the wrong splash screen?
I may end up adding a forward facing camera prior to next year's trip out west as well.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0103
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
67 Designs phone and GoPro mounts next up. Quick and simple install. I'll be extending the USB connections up to the mounts at some point.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0119
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build IMG_0133
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Warn Zeon 10s with Warn winch plate and Factor 55 flat link...
This turned out to be a bit more difficult then planned. The excellent step by step thread here from a few years back was very helpful. Unfortunately, I didn’t read to the end to see the recommendation to pull off the grill first. This helped immensely in getting the inner nuts back on the bumper to frame bolts, with the help of a small socket extension. I did have to notch the rear holes in the OEM skid plate to get it back on as many others also indicated in the install thread.
I am happy with the end result, just took a lot longer than expected.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build BCCFE5EA-41B6-4A97-B0EF-B8017ECC0948
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 6024B9CA-3DF7-4709-8DBB-6F4906435720
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 6AD03C29-D9F2-476B-96C4-01F93F147BA1
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build D106C075-2F75-406C-BFD9-9C51E5B46218
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build C9E56A65-09C1-40FF-BAC9-950AE285446C
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build ACFADDC6-D634-40CC-B0E8-11D00C1E501B
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Not a mod per say, but picked up a Rain Gear half cover. Nice fit, seems pretty high quality. I like that I can put it on with the soft top up or down, and it covers all the way to the bottom of the door frames.
Living in Florida the doors have been off more than on, so need a quick way to protect against the occasional down pour.
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 3D16BDCB-A042-470E-996B-C4D6509F8F41
Sparticat
Sparticat
Madeira Beach, FL
2020 JLU
Installed the Exposed Racks bars and clip in kayak and paddle holders today. The stock bolts are replaced with longer bolts to which the bars are mounted. I am a little concerned with how close the soft top is to the front bar. We’ll see...
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build AFE5FD22-86EF-4EDA-9A97-A0532B20DB38
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 5E439D51-4255-40CF-B1F4-4408BEB577E6
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 38AF7DF8-AA85-4DBE-801D-7958ABF87904
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 2C7439D0-8FB0-41A4-BB0E-EE4FBFBB9550
Jeep Wrangler JL “Pebbles”, 2020 JLU Granite Crystal build 0B0EA813-5252-4440-9DF0-94A773622CEE
zjwilliams
Zach
Central Florida
Jeep JLU
I love the customizations you have going on it. If you don't mind can you post a link for the half cover you found?
