Just ordered Mopar lift and other parts (What am I missing?)
ERIXJLUR
Eric
Studio City CA
2018 Granite Crystal Rubicon 2.0L (ordered on 2/12 received on 9/26)
Tonight I ordered the following:
- 2” Mopar lift
- RK correction pads (F&R)
- Rusty’s adj track bars (F&R)
- Teraflex JL control arm drop brackets
- Fox steering stabilizer
- Rusty’s Track bar support (received - ordered last week)
What else am I missing?
What are the chances that I will need adj control arms?
Silverblkrilla
Tony
JLU Sport S
- 2” Mopar lift
Might want to get a tazer or another programmer.
unsavory
Jimmy
2019 JLUR
Are the RK correction pads still needed with the updated AB Mopar lift?
I just ordered the updated Mopar lift along with Metal Cloak adjustable track bars and lower front control arms.
I really only want to do this once, so does anyone know if those pads are still needed?
Tritonman
Keith
Upstate NY
2018 Rubicon JLU
ITS Duty Manager
From what i have seen, the Mopar correction pads are not very durable and there have been instances where they crush under articulation. I would be proactive and get the RK ones.
unsavory
Jimmy
2019 JLUR
Okay, thanks for the heads up. I'll order them.
sardog12
Drew
Baton Rouge
2004 Wrangler X-Gone, 2019 Wrangler Rubicon
IT
I understand that some people have budgets that they need to work within but I would suggest staying away from the track bars from Rusty's. The poly joints that they include are not something that I would use and I would worry about hitting the diff cover with that trackbar. You can find a much better design for little more money with some other vendors. Metalcloak and JKS are two that immediately come to mind. I suggest you check those designs and compare to the Rusty's and notice how much more thought goes into the design of something which seems so simple. I have been in exactly the same boat as you are when I first modded my TJ and will not sell my old Rusty's trackbar to anyone for safety reasons after it wore away in a spot rubbing against the diff bolt.
OffRoadWarehouse
San Diego, CA
www.offroadwarehouse.com
2018 Jeep JL
Jeep, Shock, Suspension, and Export Specialist
- 2” Mopar lift
If you are doing the Teraflex correction brackets you won’t need control arms. The brackets have been working great for most everyone.
I’d recommend getting a superchips Flashcal for your speedometer, and traction control calibration
Stinger Off-Road
