Just another Black Rubincon on UD60s and 40s
Alacon01
Cody
Fayetteville
8/8/2019 Update pick and quick build list.
Use the code "Crossthread" on any links for a discount!
DV8 FS-16 front bumper
4.5" Rock Krawler X-Factor Lift
https://outlaw-offroad.com/rock-krawler-jl-jlu-4-5-x-factor-system/
Ultimate Dana 60s (5.38 Gearing)
Radflo Shocks
40" Mickey Thompson Baja Boss on 17" KMC Beadlocks.
Artec Skids (steel)
https://outlaw-offroad.com/artec-industries-jl-full-bellypan-4-door-3-6l-steel/
Artec Fender supports
https://outlaw-offroad.com/artec-industries-jl-front-fender-chop-kit-brackets/
Artec Front Inner Fenders
https://outlaw-offroad.com/artec-industries-jl-front-inner-fenders-solid/
Artec Rear inner Fenders
https://outlaw-offroad.com/artec-industries-jl-rear-inner-fenders/
Steersmarts Tie rod (JK version for UD60)
https://outlaw-offroad.com/copy-of-...r-tie-rod-assembly-jl-jt-2018-rubicon-length/
Steersmarts Drag Link
https://outlaw-offroad.com/78078001-steersmarts-yeti-xd-jeep-wrangler-jl-jt-draglink-top-mount/
Steersmarts Track Bar
https://outlaw-offroad.com/75040001-steersmarts-yeti-xd-jl-jt-adjustable-front-track-bar/
Rock Hard 4x4 sliders (Trimmed to clear 40's)
JCR Crusader rear bumper
Adams Driveshafts (Custom for UD60s)
https://outlaw-offroad.com/adams-driveshaft-jeep-jl-front-rear-1350-set-rubicon/
I've driven a few different trucks for the last few years, but finally decided that it would be ok to ditch the bed and just get a trailer for whatever I need to haul.
I used to have a white Tacoma that I loved, It was great, and when they came out with a re-design in 2016 I got a new one with every intent of building it out. Well that never happened, I just never felt like I wanted to do anything to it.
I don't have any pictures of the Tacoma after that, but I'm sure anyone can find a stock tacoma picture.
That brings me to today, about a month ago, after 6 months thinking about it I went out and picked up a new JL rubicon.
I had to wait until the JLs came out because I didn't want to go away from proximity entry and all the fancy things inside.
here is the day I picked it up.
The first thing I went for was a 2.5" RC spacer lift. I made this decision based of the fact that it's my daily driver and it has pretty solid reviews.
It's nice to work on things when they are clean.
Next I added a DV8 FS-16 front bumper you know, to hold the winch that has been sitting my garage for 2 years.
Then some 37" general grabbers.
That's where I'm at today, I'm still trying to figure out a few things, like what PSI to run in my tires, I'm at 28 right now and seems like it's still a bit too much in the center.
I see it mentioned quite a bit what the backup camera looks like so here is mine.
Keeping going I went ahead and made a mat for the back out of a 14.00 floor mat from lowes. Not the best, but it keeps things protected for now.
I also had a chance to get out to Uwharrie a bit, so here is a pic after it got dirty, it was dry so cleanup wasn't too crazy.
And a little bit of mall crawling action since this was in an actual mall parking lot.
Added a shelf to the back, would have been nicer had I not used scrap plywood, but it was a $20 mod with the plasti-dip coating included. (excuse the dust)
Put some Artec sliders underneath, this is the only shot I have of that so far
Then I thew bedliner on the interior and got rid of the carpets.
Then I added a usb port to the top of the dash for my GPS setup.
After that we got a set of method standards put on.
JCR rear bumper (Tire carrier is on the way..)
And I took it out for a little spin/ camping trip.
Last but not least I installed a Rock Krawler X factor lift. ( no pic yet)
After installing my rear tire carrier and a full load my bad end seems to squat a bit too much so I went up to a 3.5" lift in the rear.
here it is after the new springs.
There is also a good chance I may have gotten stuck
This happened before I got stuck, but I ended up getting a service shifter code, so I got to figure out how it looked on a tow truck.
Thanks for checking out my thread!
-Cody
1quick1
Moderator
Moderator
2018 JLUS
Awesome. Those red letters on the Grabbers looks awesome on the black Rubi.
MYAMIA
MyA
MIAMI
Sahara JL 2018
Amazing car. Congrats
Alacon01
Alacon01
Cody
Fayetteville
Alacon01
Alacon01
Cody
Fayetteville
I'm also working on making a shelf for the back. I had to make it into 2 pieces so I could easily take it in and out whenever I wanted to.
GringoStar
Shane
Phoenix AZ
2018 Black JL Rubicon
Would love to get measurements, or dimensions on the back shelf. I want one to cover up my subwoofer
Alacon01
Alacon01
Cody
Fayetteville
Here is what I have currently, I didn't put the holes because I had to ream mine on to fit easily and that means my initial measurements were bad.
The reason the shelf is cut in half, and the bottom half of the shelf is 1.5" shorter and has the corners cut is so you can take it in and out without removing anything but bolts.
If I were to re-do the shelf, which I still may I would make the top half about 1.5-2" shorter to fit the bag that holds the freedom panels. I would also curve the bottom a bit better since it takes a bit of problem solving until you know exactly how to get it in and out.
Alacon01
Alacon01
Cody
Fayetteville
Something like this may work. After drawing it out, it makes me want to build mine again...
Keep in mind this one is not tested at all. I wanted to take the bottom mounting points down to 1" because the bolt will fit still, but I feel like you would heavily increase the chances of it breaking.
GringoStar
Shane
Phoenix AZ
Wow that was much better than I expected. Thank you! I am going to work with this a bit to figure out how to make mine
Alacon01
Alacon01
Cody
Fayetteville
You caught me at a good time when I was already playing with it. I went back outside, I'm not sure if there really is a good way to store the freedom panels. you can cut the shelf back probably 3" or you can just leave them home. I didn't really like how the block out almost all of your rear view when standing up.
GringoStar
Shane
Phoenix AZ
I have the soft top so no freedom panel worries for me but everyday I wonder if I made the right call. I’m in AZ so it is really flexible to have a soft top but I really love how the hard top looks.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Love those red letters on the general grabbers, though I would rotate the spare so it doesn't show on the backup camera. Great looking jeep.
Alacon01
Alacon01
Cody
Fayetteville
I get that, in NC I felt like the hard top was a bit better in the winter, I also grew up in Michigan so I'm always winter concerned.
That would be interesting, however I placed the rear tire so the lettering is almost correctly horizontal. I can't wait until 2 tire rotations when I will have a tire that has almost perfect letter placement.
I also added my hi-lift and shovel to my shelf today, I've had these mounts sitting around for a few years, why not put them to use. another addition I may may to the shelf is putting some pegs in so the 2 parts don't create a seam when they flex independently.
I think the next additions are probably sliders and a 2.5" x-factor lift from rock krawler. Waiting for that perfect rear bumper // roof rack.
Alacon01
Alacon01
Cody
Fayetteville
Shelf thoughts Ep.2 .. If I were to move the hi-lift to the back, and mount the shovel underneath.. I could fit my maxtracks there and keep everything inside the vehicle. All while still having enough room to sleep with a cooler, recovery gear, and food.
Alacon01
Alacon01
Cody
Fayetteville
I've been kind of hesitating for no good reason, but today I ordered a 2.5" Rock krawler lift, Falcon shocks, JCR crusader rear, JCR shield tire carrier, Rock Hard 4x4 sliders, and a CAD skid. Hopefully this week there will be some Artec sliders installed and some method standard wheels on before I get the lift.
