We are happy to announce a JLWF / Quake LED Giveaway Contest!
PRIZE
- Pair of Quake LED JL Headlights. See full product details.
- Plus, 50% off coupon on your entire Quake LED Light build (max 6 sets of lights). No purchase necessary. Expires 1 year from end of contest.
PRODUCT DETAILS:
This patent pending design headlight comes stock with adjustable High/Low beams, DRL Accent Lighting (Bluetooth controler included), built in Amber Turn Signals and real high power 5W Osram Diodes all jamming through a 4D projector lens design. The impact resistant aluminum optic ring design provides a watertight seal. Built in Quake's German TUV approved factory and not someone else’s.
Quake LED only uses High Quality Diodes, PCB Boards, Resistors and oversized off-road durable Wiring. Durable powder coating and marine grade epoxies will provide you with the comfort of knowing this light will last as long your Jeep does. These easy to install headlights connect with Quake LED’s Easy Link, Quad-Lock Pro and Interlock Controllers giving you endless linking and control possibilities.
**All discussions/product questions can be directed here - Quake LED plug and play retrofit JL LED Headlight and Fog Lights
CONTEST RULES
Who
- This giveaway is only for members who will be installing this product for personal use on their JL Wrangler (not for resale).
- The giveaway contest starts now and will end on December 18, 2018.
- The winner will be chosen right after the contest closes and announced the following day.
- 1) Visit the Quake LED Website @ www.quakeled.com and pick out up to 6 items you would want on your build (besides the JL RGB LED Headlights, which are being given away in this contest). If you win, you'll also receive a 50% coupon on these items.
- 2) Make a post in this thread with the part (SKU) numbers of the items you would want.
- Your post # will become your virtual raffle ticket #.
- Only one entry per user. Multiple entries from the same person (or registering multiple user accounts) will result in the deletion of all your entries and suspension of your account.
- At the close of the contest we will randomly select (using a random # generator) one number which will correspond to a post #. The member who made that post will be the winner!
- If you purchase Quake LED headlights during this contest period or have already purchased their headlights, Quake will credit the contest prize value toward any Quake product.
Thanks again to our generous friends at Quake LED and good luck!
**NOTE: This is not an open thread for discussions. Any posts that are not an entry for this giveaway will be deleted.**
**All product questions can be directed here - **All discussions/product questions can be directed here - Quake LED plug and play retrofit JL LED Headlight and Fog Lights**
