- Tim
- Jan 16, 2018
- Poulsbo, WA
- 4x4 of all kinds
- Occupation
- Part of the Northridge4x4 team
The line load off the winch will always be restricted by the winch capability. In rough numbers, with a 9500lb winch, the line leaving the winch is restricted to 9500lbs. When the line goes through a snatch block the load on the line remains at 9500lb. If you redirect the hook end of the line back to the Jeep, then there is a 9500lb pull on the winch end and a 9500lb pull on the hook end ... a net of 19,000lb on the Jeep. The winch line never sees more than 9500lb.
Nice job explaining it @47Jeepster.
I'll add that the anchor point for your snatch block (pulley block) and the snatch block itself will see the 19,000lb load on them (if using 9.5K winch), so anyone making a double line pull make sure your equipment is up to par.
