The loctite on these bolts can be a pain. If you don't have an induction heater, then loosen the bolts and tighten them. Loosen them again and tighten. Repeat until the bolt comes out.@Roky @chevymitchell @BDinTX Have y’all messed with these? OP broke loose a body bolt for sliders. Don’t want him to break one.
The body bolt (one with the big washer) tightens to 90 ft lbs.@Roky @chevymitchell @BDinTX Have y’all messed with these? OP broke loose a body bolt for sliders. Don’t want him to break one.
So Shawn, are you saying using an impact in and out until loose works without fear of snapping a bolt? Definitely would be much easier if soAn impact helps with this, as well. Trying to remove them with a smooth action like a ratchet or breaker bar will not work very well. It will work, but an impact hammering on it is certainly beneficial. I have yet to break a body bolt working the bolts like this.
Yeah. If you’re easy with the impact, you won’t have issues. If you sit there and hammer on it for 10-15 seconds, then I would expect bad things to happen. When going in the tightening direction, don’t retorque the bolt with the impact. Just enough to move the bolt. 1-3 turns. Then reverse the bolt back out. This method has worked like a charm. I have an induction heater and still do this method before breaking it out.So Shawn, are you saying using an impact in and out until loose works without fear of snapping a bolt? Definitely would be much easier if so
May have to try this route soon. Have a used set of RSEs sitting in the garage I keep delaying install since not sure was ready to tackle these bolts. Of course I need to do a little cutting on the stupid new bracket they installed on passenger side frame also on late model 22s. Thanks budYeah. If you’re easy with the impact, you won’t have issues. If you sit there and hammer on it for 10-15 seconds, then I would expect bad things to happen. When going in the tightening direction, don’t retorque the bolt with the impact. Just enough to move the bolt. 1-3 turns. Then reverse the bolt back out. This method has worked like a charm. I have an induction heater and still do this method before breaking it out.
No worries at all man. I just put a set of RSE’s on for a forum member a couple months back and had to cut the bracket. It’s a small amount of material that has to come off, but it’ll work out great.May have to try this route soon. Have a used set of RSEs sitting in the garage I keep delaying install since not sure was ready to tackle these bolts. Of course I need to do a little cutting on the stupid new bracket they installed on passenger side frame also on late model 22s. Thanks bud
I may be taking that bulky bracket completely out. I know there’s couple routes to leave it and trim, but not sure which route I want to go yet.No worries at all man. I just put a set of RSE’s on for a forum member a couple months back and had to cut the bracket. It’s a small amount of material that has to come off, but it’ll work out great.
If I had one on mine, I’d take it out, for sure.I may be taking that bulky bracket completely out. I know there’s couple routes to leave it and trim, but not sure which route I want to go yet.
Nah. Pain Train still lives on in my possession. It’s currently at the body shop getting the rear quarters replaced. This one will be hard to get rid of. It’ll take the right person at the right time, I think.btw Shawn, any lucky soul end up w/ Pain Train, curious what that badass project has become???
