JLURD considerations - moving from 37x12.5x17 tires to 38 or 39x13.5x17
JL_Wildlife
Robbie
JLUR Turbo Diesel
Regear is a pure highway optimization. With the 4:1 xfer case and an automatic, you've got plenty of torque. Gears make torque. My 2.0 T that doesn't make as much torque as the diesel, easily climbs vertical with stock gears & 37's in M1 @ 1,200 RPM.
a km3 37 isnt really a 37, it's 35-36 per memory.
Mine measured 35 13/16"
Glad to hear that! Good to know. Thanks!
  • Like
Reactions: J0E
drick
drick
AZ
2016 JKUR & 2021 JLURD
so then if we assume the 39's follow suit - then I'm basically getting a 38, right? if so, this is why I'm less concerned about moving up to the 39 in a BFG.
now the 12.5->13.5 is still something i need to think about based on current rim and backspacing.
OBJLU
Henry
Los Angeles
2018 JLU Rubicon
Lol a 37 really when brand new
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
i rounded up as he had the 13/16 shown and clearly has done the comparison... :LOL:
I will be moving to 38” once I get the following done in the months ahead. I have all the parts, just waiting for time and downtime to do all the work.
Fender chop & inner fenders
RCV axles
Knuckles
Ball Joints
Truss kit
Bump stops
One ton tie rods
4:10 gears
Diff Covers & oil change
Man, now that I just listed all the parts. I should have went 1 tons and sell the stock axles.
drick
drick
AZ
FWIW - talked to shop about this earlier in the week. he doesn't think the extra weight of 39's or the extra height and width should make any material difference in the build.
i'm going to wait for the RCV's to come i think just to be safe and do these both at the same time.
drick
drick
AZ
RCV axles
Knuckles
Ball Joints
Truss kit
Bump stops
One ton tie rods
4:10 gears
then you wouldn't have anything to look forward to later... :LOL:
kah.mun.rah
Merenkahre Jr.
Duat
IMO 12.5 on 37s starts to look pretty skinny so a 12.5 on a 38 or 39 would look like pizza cutters.
drick
drick
AZ
i have them on both rigs right now, and i never had that thought on the jk. for the jl, i don't disagree - it seems that i have a lot more "white space" - even when i put them right next to each other.
on the other hand, if they look awesome but rub or mess up my suspension - then that would suck and set me back.
Atom631
Atom
New York
2021 JLUR
no tire on the market will measure true when its under the jeep. My 38” Ridge Grappler measures 36.5” under my jeep at 30psi. off the jeep it measures almost exactly its advertised size (37.76”).
Jtclayton612
Memphis, Tn
2020 JLU Sport S
For full flex I think you’ll need to do a little body trimming in the rear wheels with the bfg 39s but I’m not 100% sure.
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
True, but at 36 PSI, which the tires were inflated, they drop .05". See BT39.com
Also measured at 0 PSI before I had them mounted.
Jeep Wrangler JL JLURD considerations - moving from 37x12.5x17 tires to 38 or 39x13.5x17 2022-07-05 16.19.40
