Gregj
- Greg
- Dec 15, 2018
- West Texas
- JLU Rubicon, JLU Sport, JTuRD
Using the wiring diagram linked by @mwilk012 looks to be white/green and ground, don't know if it will need it, does 2x led= one Halogen bulb as far as amp draw? don't know.wondering which wires need to be tapped to add the resistor for front running/turns
Shane and I have already worked out him getting the sockets he needs and as I posted above, just need to file a small amount of plastic in the housing to make the socket fit. I still say its doable. Pretty simple really.So you want the DRL and turn signals to function identically? That could be hard to swing. You’ll need two bulb sockets each with two inputs and grounds or a common ground, probably identical to the sport model plugs, but I’m not sure they’ll fit the housing properly.
Everything is doable, its just whether or not it’s reasonable when other lighting options exist.
Gregj
