Little Joe
- Joe
- Apr 6, 2019
- Treasue Island Fl
- 2018 Jeep Wrangler Unlimited JL Sahara 35x12.5 R18
well mine DOES NOT RUB, HANice! Do you experience any rubbing?
Once again, most of the case when people ask about rubbing, it ha nothing(or very limited) to do with lift, it’s due to amount of backspacing on the wheels that cause tire rubbing on front LCAs/tie rod. You need to turn your steering wheel to maximum rotation to one side, and hold it there(if you let go the steering wheel with bounce backs), then have someone crawl underneath and look at clearance between tire and LCA, then craw under the other tire and check clearance between tie rod, it is from my experience that 12.5” tires (stock wheels) will rub on max turn.
