JLU rubicon suspension on sport
MudHorn4xforLife
Jonathan
Tennessee,USA
2021 wrangler 80th Anniversary Edition
Thank you, my apologies for not posting the numbers but yes 60/61 & 90/91.
MudHorn4xforLife
Jonathan
Tennessee,USA
Yes, I have the springs, the shocks and ordered the LCA’s for the 2” lift to correct the castor angle.
Skystak
Wayne
Jeep 2020 JL
i finally gave up on the "spring game" since i have now seen Rubi takeoffs that are exactly what i have on my 4 door sahara U. I have 57/58 and 89/90. At least 5 rubi take offs for sale are the same so i see no difference unless you really go to like a 62/63 ish type. So i just added a spacer. The reason is i added a steel bumper, complete toe hooks to pull it behind my RV and a Warn 10K. All added about 150 ish pounds and dropped the front 3/4". So i went through all of the above debate, read every thread. dont plan to do much but rock crawling and use the warn to pull the zero turn out of the lake when the DW gets "tto close I think".....did it all my self as a first timer, took me all day to add the spacers since i'm learning and went really slow....bottom line is what your expectations are and if you are going to big ass tires on, rock crawl etc.....if yes do a real lift. if not dont waste your time just do spacers.....
MudHorn4xforLife
Jonathan
Tennessee,USA
The big winners here are us with the 2 doors. If we are fortunate enough to grab takeoffs from JLU with steel bumpers, tow package, hardtop ect. Then we can expect 2+ inches of height from the Springs. The shocks will give us extra travel for flex. Add in 1/2 inch or 3/4 inch spacers for bumpers & winches & we have real contenders on the trail for a lot less. I’m completely happy with this budget boost.
blnewt
New Mexico
Just ask @cosine he knows!
x2, my setup exactly^^^^ :)
6.2Blazer
Ohio
2019 JL Sport
I know this is an older thread but just adding in my experience for people searching this topic in the future. Started with a '19 Sport and swapped in Rubicon springs, shocks, tires and wheels. Honestly I forgot to take actual measurements but visually it obviously lifted it a small amount as there is as much, or slightly more, tire clearance in the fenders even after the good bit bigger tires.
Stock setup
Rubicon suspension and tires
