JLU Rubicon on 35s no lift
Jteakus
Oil City Louisiana
2020 Ecodiesel Unlimited Rubicon
Calemasters, you can run a 315 on the stock wheel no problem. It is almost a 35 incher
redelses
St George UT
2023 JLUR
Did you get the C or E rated KO2s? Looks like the venomrex gives it a little wider stance too?
I have my new 35s BF K02 on Venomrex, actually much better then stock ride. Cabin noise actually dropped, I spend my time on the phone and people on the other end actually noticed :(
Jeep Wrangler JL JLU Rubicon on 35s no lift 20201217_203935
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
Yes I can but the tire is too wide for a 7.5" wheel. It is not recommended. The tread width is 9.9" which is too wide for a proper fit on a 7.5" wheel and will affect highway handling.
Jeep Wrangler JL JLU Rubicon on 35s no lift tire
RabidBear
Rabid
2021 Wrangler Rubicon Unlimited
Staff Software Engineer / DBA / SQL / ETL Developer
35's No Lift 2021 JLUR
Jeep Wrangler JL JLU Rubicon on 35s no lift IMG_3865
Jteakus
Oil City Louisiana
For those that don’t know, the 315 C rated BFG KO is a Ford Raptor specific tire that happens to fit our needs perfectly. Looks like we may be getting another gift from the Blue Oval, check it out.
Austin23
Austin, TX
2020 Jeep Wrangler Rubicon
I wanted to keep mine low and run 35’s. Diesel models sit level from factory. I added 3/4” spacer after winch install to level it. With 35’s on stock wheels I’m getting a little rub on driver rear inner fender liner where it bulges over fuel filler tube. Really no big deal but I ordered 3/4” rear spacer and 1.5” for front to replace existing 3/4”. Will report back after install.
Jeep Wrangler JL JLU Rubicon on 35s no lift 5B1AEF61-B59E-49E9-BAA9-2618EFFFCF30
Nice ride! Did the 3/4 rear spacer make a difference? How does it handle the trails?
TheMAnderson
Orange County, CA
2020 JLUR 3.6L (sold), 2022 Tundra Limited Hybrid
The Falken M/T are a no charge option. The BFG K02 are the stock selection. Just a click of an option box when the dealer orders them is how the selection gets decided.
Actually I think it depends on their supply. I chose M/Ts also, but got BFG KM3s, not Falkens
JPajot
Jean-Louis
Acworth, GA
JLU Rubicon
more tire pressure (or less maybe)?
The tire pressure on my 35's were set to 30lbs. You will need to reset your onboard computer's TPMS setting to the the lower pressure or you will get a low tire pressure error. I used the Superchips FlashCal programmer to make the necessary adjustments to the tire height and pressure.
Wraif
New Jersey
19 2-door manual Rubicon, 09 JKU
Hi, first post. All this talk of tire rub brings up one question for me. If the tire is hitting the fender liner, why not just move the fender liner ? I have a set of 35’s in my shed that I will be putting on my Rubicon that were from my JK Rubicon. GY MTR’s on Mickey Thompson Classic III. I was also worried about making contact, so I got American Adventure Labs High line fender chop with aluminum liners. After researching them more, I can go to 37’s with no lift. Or so I’ve been told. When I get them on, after all this snow goes away, I’ll take pics and post.
Steel8083
2021 rubicon
35x12.5x17 Nitto Ridge Grapplers
17x8.5 -6 Fuel Trophy
Jeep Wrangler JL JLU Rubicon on 35s no lift A8225FE9-BA6E-45AE-BC7E-FA4F1D5F4D33
Well I see this was a year ago but ive been wondering about the anthracite/gray color with the granite. They look very good is the color as close as it looks?
