JLU Rubicon on 35s no lift
Watchtower02
Wisconsin
Wrangler
Is it dumb to put 35” on stock wheelsShould one just by wheels that fit? I mean are you asking for trouble...
looks the the tire dips into the wheel and looks almost kind of like an inflatable doughnut, but not sure if that’s the way it looks in person. Maybe it’s just the pictures?
I am looking at the 35”x12.5x18 Nitto ridge Grappler.
JRod
Jarrod
North Carolina
Because the rim is more narrow, there definitely is a little more tire buldge from the sidewall, but it's not bad. I think it helps protect the wheel a little bit to prevent wheel rash. Some folks say that it makes it less likely to come off the wheel when aired down, a "poor man's beadlock."
moonlit
Pittsburgh PA
2020 JLUR
Fuel Trophy 17's with BFG KO/2's (315/70/17) no lift
Nomoracin
Virginia
JLU Rubicon
I finally got my new set of wheels/tires on...
2019 JLUR
stock suspension
black rhino roku wheels (17x9.5) -18 offset
nitto ridge grappler tires (315/70/17)
they seem to fit really well. i don't rub
what psi should I be running for daily driver btw?
aphillips76
Aaron
Denver
2018 JL 2 Door
Not JLU but here’s mine... 17x8.5 0 offset with 315 ko2s... No rubbing at lock. Will get back to you on rubbing at flex.
Jeep Wrangler JL JLU Rubicon on 35s no lift 6DE28DA8-722A-4AC2-9817-BA96DDBE4028
Jeep Wrangler JL JLU Rubicon on 35s no lift 4FD624CB-88E7-4A81-A231-46D0D36960A6
Fsttanks
Tony
Palm Springs Ca.
2013 JKU / 2014 JK / 2020 JLUR
Waited a month to install “35s” on our JLUR. Going to stick with the stock rims as I did before on my JKU but this time I see no need for spacers. Fit is near perfect IMO with no rubbing on control arms at wheel lock to wheel lock while moving forward and in reverse.
Interesting was the expected yet minor indicated speed change comparison between the speedometer and stand alone GPS. It showed 35mph = 36.5, 66mph = 70.1 and 70mph = 74.5. Granted I was going from 285s “33s” to 315s “35s” and I suspect the difference would be more for a JL/U with the slightly smaller factors 265 tires.
I will be correcting the speedometer with an AEV Snap shortly.
Below “35s” on stock rims no spacer or lift.
Jeep Wrangler JL JLU Rubicon on 35s no lift 32AD6B5B-304D-4979-9C49-A53E5BEACBE2
Jeep Wrangler JL JLU Rubicon on 35s no lift F997A361-F413-4796-92E3-B39E1731F2C3
Jeep Wrangler JL JLU Rubicon on 35s no lift 503930F8-BB9D-404B-B0D1-BA69F36AEA8A
Jeep Wrangler JL JLU Rubicon on 35s no lift DF969894-9041-477F-B6B9-9F73FEC905C7
Jeep Wrangler JL JLU Rubicon on 35s no lift 7F921B1C-1E6E-4098-8007-8F3FF38A6D4A
A note on this last photo above the wheel is not bent outward, it just looks that way do to the angle of the photo.
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
Obviously this is a matter of taste, but I think that a lifted JLUR with 35s looks undertired - too much gap to the fender. It will take 37s to really fill out the wheel wells and balance things out. I'm going unlifted with 35s.
cjaama
Albany, NY
2019 JLUR
Looks good. Are those C rated? Any notable difference in ride?
