JLU oil change frequency
cb4017
Cliff
Northern Nevada
2019 Wrangler Unlimited Sport
@Amaruq
Not mandatory, but a 3.6 owner that is doing his/her own oil changes, probably should have one of these on the garage shelf all the time.
The cap is known to crack so, it is cheap cheap insurance ($15.00) to have one on hand.
https://www.amazon.com/gp/product/B00TO1NX8W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
--A month or so ago, I even had a local tech call and ask me if he could have my new spare cap as he could not get one right away and he had cracked a cap on a clients Jeep. The tech knew I kept a spare as we talk/brain storm pretty often. He borrowed and replaced it with a new one a week later.
Good idea. Added to my list. I also tighten this to just snug. The o-ring keeps the oil where it's supposed to be.
cb4017
Cliff
Northern Nevada
Wow, I thought the snap inside was just like a plastic ridge or something. I´ll have to take a look. Didn´t realize there might be multiple parts in there.
If there is a spring exerting pressure on the filter, maybe that´s why some twist and some don´t. Maybe some variance in the spring rates?
I believe that's actually the pressure relief valve spring. It's in the cap since the filter does not have one.
DanW
Indiana
@DanW
I was going to look this morning but forgot to. Don't have time to look at the one on the shelf right now but I will be..
On edit: I just looked at the one on the shelf.. and I can't really tell.. and I'm not gonna break it open... 8-)
If a spring there, yes, what you said, could be the reason for twist or no twist.
I just took a cursory look, as well, and I don´t see a reason for it. The little plastic nub certainly could have a spring in it, but I felt and pushed around and just can´t see why or how it would function. But there certainly is space in the nub to house something. If I ever break one, I´ll tear into it further. But like you, I´m not going to sacrifice 15 bucks for it. Lol!
DanW
Indiana
That would make sense. I just don´t see how it would work. I pressed all over the thing and felt no movement. Maybe I didn´t press hard enough?
Amaruq
Atlanta
JLR 6spd
@Amaruq
Thanks. I saw you post this one elsewhere and ordered one too.
txj2go
DFW
How often should the oil be changed on a 2018 JLU 3.6l? The dealer suggests changing the oil every 3,000 miles....which pretty frequent.
When I started as a mechanic a long time ago, we recommended 3k. That was with dino oil, there was no synthetic back then. We got a lot of motors in our shop that didn't go past 80k miles. Those may have never had the oil changed, just put more in when it gets low. I don't remember the typical manufacturer recommendations but it wasn't nearly as long as it is now. I remember when Mobil1 came out about the early 1980s and they recommended 25k oil changes. I tried that in my own car and lost a cam well before 25k miles. Most cars I've owned the past many years have used synthetic and somewhere around 8k miles has been the average recommended interval. Using a good oil under normal conditions there should be no problem going to about 8k. Of course you can change at whatever interval you wish but also if you aren't changing it yourself, find somewhere that you trust to do the work. There is a thread on here about someone losing a wheel because the lugs weren't tightened- I've heard of drain plugs not being tightened and people losing an engine.
Another factor that might come into play- I don't remember the numbers now but besides a mileage interval there used to be a time interval. I thought maybe it was recommended to change every 6 months, or 12 months. I've been working from home the past 4 months and have hardly driven at all, for my DD car I've only filled it up with gas one time. So if we go strictly by mileage we might not need a change for 2 years or more. This is well beyond the time interval typically recommended.
DanW
Indiana
Lost a Ford 3.5 Ecoboost due to a quickie oil change place double-gasketing the oil filter. They failed to check it. The old gasket stuck to the mating surface and they put the new filter on over it. When the oil pressure was up, the oil blew out from between the gaskets. Engine became a bag of metal shavings. Fortunately, they took responsibility and their insurance paid for a dealer-installed Ford remanufactured and warranted replacement engine. It cost their insurance about 11 grand for the enine and labor. Ouch! I change all of our vehicles myself except for that Transit van. It is just too low to the ground for me.
TEXGOAT
2018 JLU
I changed mine (3.6) at 1,000 miles, in part to check for unusual break-in debris. (No issue there) I went with Pennzoil Platinum 0-20 and the Mopar filter. I'll change it again at 4-5,000 and go back with Pennzoil 10-20, which may extend timing chain tensioner life and should be fine in cool to blistering hot weather in a run-in engine. I don't get extreme cold weather here, and my Jeep stays in an insulated barn which never drops below about 50 F. I save my used oil in a clean container for general lubrication use and make-up oil in beaters that leak or burn some oil.
1quick1
Moderator
Staff member
Moderator
2018 JLU
I find the on board monitor to be pretty accurate and definitely takes in account your driving conditions. Using Penzoil Platinum full synth I would have no problem going 8-10k miles but usually change it out when the computer is around 20% life left. It's so easy and cheap to do. Especially when you get lucky and find 5 qts Penzoil for $16.
5ABI
Long Island
2020 JLUR, 8 spd Auto, 3.6L Pentastar, no modifications
Business Development Manager in a very large Osaka, Japan based Corporation
I have a 3.6 JLUR and usually do sometime between 5k and 7.5k miles or every 6 to 9 months (whichever comes first). I do limited beach off roading in summer on Long Island. My mechanic uses 0W-20 that the manual recommends. Mechanic recommended to never exceed 10k miles or 12 months between oil changes given my use condition. But if I was taking my JLUR to the sand every weekend, he recommends under 5k miles or under 6 months (whichever comes first). For hardcore rock climbing or wheeling, he recommends 3k miles or under 4 months.
Only used one of my four complimentary oil changes from the dealership before I stopped. Waiting 3 hours for an oil change is just absurd.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
You won´t have a problem using Mobil 1. It meets SAE specs. My dealership actually sells Mobil 1 for their premium changes. I´ve never heard of FCA denying a warranty claim because someone used Mobil 1. That would be impossible to defend. On the other hand, Pennzoil Platinum is outstanding, so you don´t lose there, either.
Mobil 1 isn't approved by FCA because of a pissing contest between corporate leads at both companies.
mwilk012
Oklahoma
It should be noted that using lower quality oil filters necessitates an increased oil change frequency.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Cost me very little to do the oil change this morning > $3.98 for the on sale last year, Mobil 1 M1C-456A Extended Performance Cartridge Oil Filter and then a 5 qt. container of Pennzoil Platinum Full Synthetic Oil at a cost of $12.00 after rebate. 15 min. labor.
Total cost of oil & filter change = $ 15.98. (not a typo.. cost was $15.98)
and ...................No friggin nitwit oil change guy/gal, at the dealer touching my JL, overfilling with oil, me sitting there of an hour, no drive to and from the dealer..
Guy/gals can also get the oil and filter at very low prices and do their own oil changes. As you said @cb4017, " It's easy to change and not that expensive." It amazes me that a Jeep owner can't take it upon themselves to do an oil change at home versus having a dealer do it.
Hi Rhinebeck, I have a question. I do my oil change every 5k with fully synthetic but I have the dealer do every other one to show my Jeep is going in for service. Do you worry if something happened to your engine they’d say “hey you never brought it in for service so we can’t honor your warranty”?
sf5211
Bronx N.Y.
New 2019 JL
Plumber
I usually just run Wix, but I'll run any brand. If you're doing 5k I would not buy high end filters, just wasting $
Call your local NAPA, Parts Plus, Parts City or CarQuest and ask if they do the bi-annual Wix filter sales (usually spring and fall). You can get the Wix for a few bucks, just buy several.
edit: 4/19 I paid $3.70 ea for the Wix 10010's during the filter sales
I’ve gotta disagree with ya D60, when it comes to my Jeep I don’t want the old saying “you get what you pay for” to bite me. I think the OEM filter is 12-15 bucks.
Worth it to me.
I’m not trying to knock you for saving a few bucks. Just not with my engine life.
