Poseidon
Ok so first thing. I moved CB antenna from the back top of tire carrier (see pic)to the front bumper passenger side corner. Due to fact I wasn’t getting good reception coming up with all rescue equipment hi lift shovel sand base and basically not getting good reception. Now it should be better since my buddy was the one who had same set up and his CB kicks some azz. So The bracket I wanted to install came with half inch screws. Even making pilot hole, the screw wore out trying to just start entering the front steel bumper. Lol. That ended that. Got some nice stainless steel nuts(plastic inserts stay locked)bolts, and some lock washers. Lined up bracket. Made marks through holes. Then drilled size of bolts. Then attached it and tightened all. Attached the upgraded fire stick 2....5 footer. Today I’m going to run antenna cable to front bumper then attach my SWR meter and get a good or best I can out of it.
