JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic
JLRyder
2019 JLUS
Months of research finally produced an opportunity and I pounced:
  • Like
Reactions: JAY
JLRyder
JLRyder
2019 JLUS
Removed the euro splash guards from the front bumper and started on the wheels and tires, Micky Thompson ATZ P3 35” mounted on Rovos Kalihari Charcoal w/ machined lip.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 758A1C6E-4B4F-4656-9253-BC93E367331D
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic FE2E8EA4-BEA8-4F14-91A8-A74780B5B085
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic B9C7D843-EF92-43C3-91F3-A944276E8437
JLRyder
JLRyder
2019 JLUS
Solved the pinch weld with a Rubi-rail takeoff from a guy on Craigslist.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic A0C8211C-512C-46B6-8586-B516A96760EA
JLRyder
JLRyder
2019 JLUS
Wheels and tires were round 100 pounds each, reading on the forums, I knew the gate hinge would take a beating from the weight of the spare; so decided to pony up for the Rugged Ridge Spartacus HD tire carrier.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic CD4C01F8-D8DF-4407-8F4A-7C034CAD2A4F
JLRyder
JLRyder
2019 JLUS
The lift I wanted was/still is way out of my budget right now, so decided on the Teraflex 2.5” spacer kit with shock extensions to fill the gap for now.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic E44E1F02-BE66-4B80-ACB3-7E8006FFD0C0
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic C17287B1-38BA-4B97-9240-E1D74AFC0535
JLRyder
JLRyder
2019 JLUS
Steering got really squirrely after the lift, I thought a steering damper would help, so I installed the Falcon Nexus 2.2 Fast Adjust stabilizer. While a cool piece, it did not solve the issue; got on the forums and learned about caster, then added the longer front Teraflex Sport lower control arms and Teraflex Alpine adjustable front track bar. This solved the issue and the steering is back to normal.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 53EA7EAF-C56A-4DE1-8B26-A2172A27767F
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic B431F15F-DFCD-41EC-A90D-2157BE6A3245
JLRyder
JLRyder
2019 JLUS
Happy with the look so far I wanted to add a little contrast to the front. Decided on a flat black decal.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 10A581C9-440E-4D2D-B32A-92A108C00F42
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic A9F449AF-7D45-4894-ABFF-1BCD6B4D79C1
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 43592115-91F4-44AA-8BD7-F355BCAB8F9C
JLRyder
JLRyder
2019 JLUS
Spent 6 months deciding on what way to go with the bumpers. Finally decided on a stubby, then committed to the Rugged Ridge Arcus. Again, the winch I wanted (Warn or Ramsey) was out of my budget. So I opted for what I felt was the best value for my must haves. Chose the Rugged Ridge Trekker 10k, synthetic rope, with the wireless remote. I then added the factor 55 pro link.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic B0E3EE6B-6697-4C7F-A602-E69D146A3437
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 46411F18-083F-41FF-A6F5-FEA4DFE262BC
JLRyder
JLRyder
2019 JLUS
The rear Rugged Ridge Arcus bumper was purchased direct since it’s not for sale on Quadratec till October. Added Quadratec’s 3/4 shackles to finish out the look.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 1369E213-78AC-4BA2-9CD2-D79F0D405A65
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 328B58D8-EC1F-4249-BFAB-E9F8AB1C23AC
JLRyder
JLRyder
2019 JLUS
Had to solve the license plate issue. Chose the Rough Country kit, then used the Quadratec LED plate light (liked how it had a factory connection) then cut and spliced a parallel wire up to the mount. I’m not too fond of the location, but it will work for now.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 06C5859F-9DC0-4364-A875-48A1FB19C9C8
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic D8BBBE2A-4F49-4810-B257-BE6409766CAE
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic E752ED40-42E4-4642-8E11-83E7214BF739
JLRyder
JLRyder
2019 JLUS
Wanted to clean up the look of the gas cap. Settled on the mopar solution.
JLRyder
JLRyder
2019 JLUS
It’s Florida and the Jeep was an oven. Looked at options for a headliner (Hot Heads) but settled on the Top Liner from Cover King, as it looks like it should have come from the factory this way. Temps and noise reduction are on par with their claims.
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic DC2C41F4-4D09-4A4B-B44B-325BF75DE9A8
IslandNomad
Islander
Austin, Texas, USA
2021 Jeep Wrangler Unlimited Rubicon
Jeep Wrangler JL JLRyder’s “Rocket” 2019 JLUS Granite Crystal Metallic 6F6BF055-4255-4163-9822-99300EE5091E
I am considering this same combination of Arcus bumper + Trekker S10 winch. How has it been working for you so far?
JLRyder
JLRyder
2019 JLUS
Very good so far, clutch handle does not like the salt so keep some oil handy to stop the corrosion. Otherwise it’s a great bargain for what you get.
JLRyder
JLRyder
2019 JLUS
Oh also, if you do get it, there will be a small loose wire that has no obvious home coming from the relay box. That is a chassis ground and needs to be attached to the winch. Not something in the instructions and won’t work without it configured this way.
