JLRs with 35s
Kllrbee
IL
Jeep
I have 23k on my factory 285/70/17s. Nowhere near needing replacement. But id be curious to see some pics of our 2 doors with 35s (or 315s). Lifted or not. Please specify setup.
Heres a vid with 315s
Jfmoore79
Josh
Bowling Green, KY
2021 Wrangler Rubicon 2 Door - Just Ordered!
Mopar lift and 315s
Jeep Wrangler JL JLRs with 35s AD315546-7C9A-4200-9DE2-80020917BA6B
Jeep Wrangler JL JLRs with 35s EBBD19E6-22D9-41EF-A754-52E7B799938E
dshark1
Sunny
Fort Lauderdale, FL
2021 Rubicon JLR
ALL-TERRAIN T/A KO2 LT315/70R17 113/110T C
I have 285”s oem tires on mine. I am Contra plating but reluctant to add spacers to get a wider looking stance. I Would like the tires, maybe to poke out of the fenders a tad. with the 315”s on factory wheels, How much wider would u say ascetically the 315”s are? Any pics from the front & rear would be greatly appreciated! Which off road lights do u have on your rig? Thx
benny_rt2
Benny
Baton Rouge Lousiana USA
1989 YJ - 1999 TJ - 2004 TJ
With 315s on factory wheels, do tires rub anything at full turn lock? Did you have you adjust any turn stops? Thank you. These all look great.
Kllrbee
IL
Jeep
2019 JLR no lift.
Stock fenders optical illusion appears lower in the rear.
Jeep Wrangler JL JLRs with 35s IMG_4572
I see these are Toyo MTs. Cant tell if 315 or 35. Also, how come looks low in rear? Lots of weight in back?
I only ask cuz I got a beat locally on some 35/11.5/17 nitto trails. They have an overall diameter of 34.75 whereas the BFG KOs in 315, which seem to be the go to for many here, are 34.4.
I just dont want to run into a problem with rub if I get them.
Vanburi
North Texas
2019 'Mojito' JLR
Ye, Toyota MT's. They are 35x12.50x17.
As stated in the original post, low in the rear is an optical illusion. The front fenders are much higher away from the tire tops by design.
JPAloha
Calgary
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE
Accredited Financial Planner
35x12.50 2” Mopar lift.
Luis Angel Reyes
Puerto Rico
Rubicon 2D StingGray, F-150 SuperCrew, Venza
Here is some pictures, also here is a link from another thread with very good information about the tires. The lights are Mopar, 82215386AB (7”) and 82215385AB (5”)
