Gotcha-Again-LOL
- Geoff
- Jan 29, 2020
- Flint, Texas
- 2019 Jeep JL Unlimited Rubicon Mojito
- Vehicle Showcase
- 1
Right...I went a degree beyond 90 on the flat spot next to the diff and also measured at knuckle...if you have shimmy over washboard or potholes I recommend taking your front control arms and lengthening them another 1/4 inch at a time until it goes away...Don't be afraid of going a bit over 6 degrees every jeep is slightly different. good luck! Make sure your track bar is torqued and not moving back and forth either of course.This may be a dumb question but you like 7 degrees of positive caster? And I believe that if the flat spot at the axle is 90 degrees, then you have 6 degrees caster. So you bring it in one more degree? I ask because I am getting a lot of feedback coming from my steering.
