JL Window Sticker and Build Sheet Order Tracking
Edge Hawk
Asa
Freeland, MI
2021 JLURD on order, 2014 JKUR & 1992 M101 CND 2 trailer
I'm planning to fly up as soon as he has availability / it arrives, and then I'll drive it back. The autotrain sounded awesome, but it's quite steep to get a room/cabin.... and I've done that ride in coach class, and never again.
Yeah, I always wanted to do the train to go down to jeep beach or something but never did. now I live in Michigan.
I'm a little concerned about the break-in period for the diesel and it being all highway (~600 miles). I may plan my route to avoid some of the highway and get some variation.
Advertisement
WillysGirl
Dara
Mahopac, NY
2021 Jeep Wrangler Willys
Crypto Update
Completes
AdamPCNoleDrigoHolly
JTBkmac1Mike8194RubiconJRD
RubiSnazzruby123stevepyoon
Builds Found
NameOrdered
JennnyB11/6
MaggiesJL10/15
S63036N10/26
CNDJeepLife
Ontario, Canada
2021 JLUR
The build date is usually updated in the order confirmation page of the Dealer’s upcoming orders... 8weeks huh! I believe you should have yours in next couple of weeks for sure...
I’ll have to ask about that date the next time I speak to the dealer. BX to delivered in 2 weeks would be amazing. My guess is you and I will see our Jeeps at the same time.
Samister
Sam
Barrie, Ontario, Canada
21 JLUR
If the same time is before Christmas, count. me in man!
JeepFan
Arizona
2021 Sport 2-door
I always break in new vehicles entirely on back roads - gentle cruising and lots of speed variations.
WillysGirl
Dara
Mahopac, NY
Crypto Update
Completes
Mcneal2MichelleMcGSemSpiroKarras
Builds Found
NameOrdered
61030310/22
Schruender11/19
zouch
Berkeley, CA
XJ, JLUWD
that's kinda' like what i was doing yesterday.
there's a lot of focus on how to break in a motor, but not often as much about many of the other parts of a vehicle. FCA claims the torbodiesel doesn't require any break-in, but i have to wonder about that, and after all, it's only one part of the drivetrain.
it's not all only about seating the rings of a new motor; tires, brakes, ring and pinion gearsets and other parts all have their own "best" ways to break them in. i try to come to what i think is a good compromise.
before i signed any papers, i spent some time with the vehicle making sure it: a), was what i ordered, and b) ready to drive.
having done a little amateur racing, i do a sort of minor Tech Inspection with any vehicle i'm going to spend time with. tire pressures were all surprisingly close to spec, but wheel lugnut torque was all over the freakin' place. (i have a thing about tire pressures and lugnut torque; i bring a gauge and torque wrench with me every time i know someone has messed with wheels or tires, because 90+% of the time when i check afterward i find the values are wrong.)
yes, true to form, as reported here every single one of the relays in the fusebox was not fully seated, and roughly half the fuses were not fully seated either. unlike the last J**p i ordered however, the battery was securely mounted; the last one i got was so loose the brackets fell off when i touched it!
with that out of the way, it was time to drive it.
i started out doing some gentle acceleration until it was indicating near full operating temp (trickier since diesels warm up best under load), doing nearly a dozen frequent near-stops of increasing intensity to heat up the brakes and bed them in, all while not getting up to highway speed for long so as to not get the tires and the ring and pinion gearsets too warm for their initial heat cycle. didn't get on it much at all until it was up near operating temp, then gradually worked my way deeper into the accelerator. shut it down in about 20 minutes and parked it (without using the parking brake) to let the gearsets cool down for their first heat cycle.
after an hour or so, took it out and warmed it up again on surface streets still keeping it under full highway speeds, gradually getting deeper into the accelerator to work in the engine and the rest of the driveline; shut it off after about 30-40 minutes to let it all cool back down again (again, without using the parking brake).
after nearly an hour, drove it home the long way through the backroads, which forced lots of varied accelerator input and braking. got much deeper into the accelerator (OK, all the way! ;)) after it had been at full op temp for most of an hour, and enjoyed the torque of the 3.0. finished up with a short cruise down the freeway before some surface streets in to home.
this break-in isn't perfect, and ideally there would be some way to heat cycle the tires a few times before flogging on them. i figure the tires are the most expendable part of the vehicle when it's new, and (in most of our cases) an expendable wear item likely to be replaced with something else sooner than gearsets, turbos, u-joints, and transmission components, etc.
i'll be nice to the next set of tires and heat cycle them more appropriately, as the rest of the vehicle will already be past initial break-in by that point.
i only get one chance to do an initial break-in of a vehicle, so will be happier knowing that i did it the way i wanted it done. it's not just that it's a significant investment, but the way we use these machines in the places we go, i'm trusting my life and that of others to this thing working properly. it may not make *any* difference, but if i didn't do it and something broke down the road, i'd be wondering about it forever.
WillysGirl
Dara
Mahopac, NY
Crypto Update
Completes
1C4HJXDG0MW6...610303ArielBroseFinDog1
HoutexccJaysonJoejeepKyle5217OL3PUT
Oldcoloradoj...PhillysWillysS63036N
Stickers Found
NameOrdered
KyWillys10/15
nomographer
Seattle, WA
21 Rubicon ("Anaximander"), 94 YJ sold :(
Past Year
Request-to-BuildBuild-to-StickerRequest-to-Sticker
33.85.446.4Overall
33.34.943.0Model 2021 Jeep Wrangler Sport Unlimited
34.04.445.4Model 2021 Jeep Wrangler Sahara Unlimited
34.54.145.6Model 2021 Jeep Wrangler Sport
32.95.147.5Model 2021 Jeep Wrangler Rubicon Unlimited
38.03.548.7Model 2021 Jeep Wrangler Rubicon
31.65.842.8Engine 2.0l Turbo
34.85.247.5Engine 3.6l Pentastar
33.05.847.8Engine 3.0l Turbo
33.25.646.1Doors 4
35.94.947.7Doors 2
Lag
(Relative to model average)
(Property appears in >2% of builds)
(Request-to-Sticker more than 1.0 days from average)
(Properties do not necessary cause delays; a related feature may be the culprit)
-1.781.20-4.77Front Mopar Grab Handles
-1.781.20-4.77Mopar Grab Handle Kit
-1.071.04-4.74Rear Mopar Grab Handles
-0.483.45-3.84Mopar Hd Rock Slider W/step Assist
-0.310.86-3.65Mopar Black Tubular Side Steps
-6.19-1.21-3.34245/75r17 All Terrain Tires
-2.330.70-2.882.0l I4 Dohc Di Turbo Engine W/ Ess
0.73-0.77-2.8017x7.5 Black Steel Styled Wheels
-0.90-0.01-1.46All Automatic Transmissions
-0.28-0.41-1.343.6l V6 24v Vvt Etorque Engine Upg I
0.33-0.75-1.18275/55r20 Bsw All Season Tires
0.33-0.75-1.1820x8.0 Fully Painted Alum Wheels
0.33-0.75-1.18High Altitude Package
0.000.000.00Spring - Left Front
-0.241.501.25Body Color 3-piece Hard Top
0.720.491.25Steel Bumper Group
2.753.571.50Mopar Stitched Leather Black
-1.121.011.6818x7.5 Gloss Black Alum Wheels
-1.121.011.68Altitude Package
0.97-0.011.73Mopar Satin Black Grille
0.681.372.00Mopar Black Fuel Filler Door
2.192.642.34Mopar Hinge-gate Reinforcement
3.83-0.812.45Mopar Dual Top Group
0.931.592.49Lt285/70r17c Bsw M/t Tires
-2.952.672.67Premium Tan Sunrider Soft Top
0.732.832.96Mopar Stainless Door Sill Guards
2.33-0.843.61245/75r17 All-terrain Tires
1.12-0.383.89Engine Block Heater
0.070.834.55Dual Top Group
2.910.044.833.6l V6 24v Vvt Engine Upg I W/ess
2.910.044.83All Manual Transmissions
1.594.736.09Mopar Perforated Leather Black
11.47-1.699.29D1-to-d Regress
Jeep Wrangler JL JL Window Sticker and Build Sheet Order Tracking percentiles-request-to-build
Days since request, no build sheet nor sticker, request in the last 100 days
p20: 17
p40: 23
p60: 37
p80: 61
p90: 74
p95: 81
p100: 97
CJ555
Philly
No Jeep, YET!
Received sticker before build. Is this is normal?!!
Build still not found.
Also,....I read custom builds have customers name on them ,.....Is this for the actual sticker on the Jeep? Because I do not see my name on sticker in the email I received
zouch
Berkeley, CA
XJ, JLUWD
the window sticker in my J**p came with my name printed on it; i was told the actual physical sticker in the window was the only one that would.
it might get framed. :)
CJ555
Philly
No Jeep, YET!
LOL Mine too!
Did you et your sticker before your build? For some reason I figured it would be the other way around??
WillysGirl
Dara
Mahopac, NY
It is usually the other way around, but sometimes the build sheet misses the system. I've seen a lot of stickers come through first lately.
Advertisement
Advertisement
