JL wheels on a JK hub? Trailer application.
Myron
Myron
Mitten State
2020 Wrangler, 1964 Land Rover SIIA 88
Hello everyone. I'm completing a camper-trailer build and in order to avoid carrying both a trailer spare and a vehicle spare, I'd like to put Jeep hubs on the trailer so that I could use the Jeep's spare wheel/tire should the trailer get a flat. My local guy told me that JL wheel studs are slightly bigger diameter than JK wheel studs, but that it wouldn't be a problem fitting a JL wheel on the JK hub (presumably because the holes in the JL wheel are slightly bigger than a JK wheel's holes).
I am therefore considering putting JK hubs on the trailer's axle. Am I missing anything here? Sound like a viable approach?
I am assuming that my local Jeep shop suggested this approach because JK hubs and wheels would be less expensive than JL.
Thanks,
Myron
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
Both wheels are 5x5 lug pattern. The mechanic is correct about the actual size of the bolt studs being used on the JK and JL wranglers. Use the correct size lug nuts for the size bolt in the trailer axle
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
the bolt pattern and hubs are interchangeable. the wheels are interchangeable.
Myron
Myron
Myron
Mitten State
Excellent! Thanks guys.
Myron
