sdynak
Awesome! Did not know.. thank you!Actually those are available here:
https://www.jlwranglerforums.com/jeep-jl-wrangler-wiring-diagrams/
I've spent about $300 in the past for 3 volume sets which included a electrical schematic volume. Easily worth it, saved me $1000s on repairs I did myselfIt's been my experience that each manual is licensed to a specific person and is prohibited from public distribution. So a "group buy" or a co-op purchase of a license may not be authorized. I supposed it might be able to be done using the same concept of a shop who has a copy, which all the employees can access. In which case maybe making it only available to those who participated in the purchase would allow it to be done. IDK, I'm just brainstorming here, but I doubt they'd allow you to post it on the public forum for anyone to access.
That said. Having had service manuals for several Rams, I'll agree with wv18jl, and say that they're worth the money. Over $100 is a lot of money for a manual, but these are by far more detailed and informative than Haynes or Chilton manual and those things were considered to be a "must have" item for every DIY mechanic. The best part is the service manual is specific to each year (not a range of years) and is made by the manufacturer of the vehicle, not written as the result of a tear down and rebuild like Haynes. They're actually OEM instructions on how to take stuff apart and put it back together. It's worth the money, especially if you plan on doing many mods.
Out of stock for the 2018!!!I've been waiting for the 2018 Wrangler JL service manual (https://www.techauthority.com/en-us/products/81-370-18071-SUSB) to become available for a few months now. The 2019 Wrangler section had no service manual entry. Recently, I discovered this site misfiled the Wrangler service manual under the Cherokee model section (https://www.techauthority.com/en-us/products/?year=2019&model=877&type=4). If anyone is still waiting for a service manual on USB, the 2019 is available at the second link and should be nearly identical to the 2018 model.
Thanx for this.. As others have said, $140 isn't a lot if you consider the time and possible damage saved knowing the factory process for R&R.I've been waiting for the 2018 Wrangler JL service manual (https://www.techauthority.com/en-us/products/81-370-18071-SUSB) to become available for a few months now. The 2019 Wrangler section had no service manual entry. Recently, I discovered this site misfiled the Wrangler service manual under the Cherokee model section (https://www.techauthority.com/en-us/products/?year=2019&model=877&type=4). If anyone is still waiting for a service manual on USB, the 2019 is available at the second link and should be nearly identical to the 2018 model.
So by doing this you get it for less but do you know if purchasing the manual includes updates when they occur? Is this method not a complete manual? Trying to weight the options.I just bought the 3 day membership for Tech Authority which is like 27 bucks. Then I just downloaded the PDF of everything I think I'd need. I pretty much got most of the wiring diagrams I needed etc. ITs worth it.
By doing the pay for 3 day thing you have access to the entire Tech Authority site. You don't download a MANUAL per se. you actually have access to the Tech's see. So for example you see an INDEX when you login and you have to search by Electrical, Body, etc and then you see the diagrams etc and can PRINT to PDF. So for example you will downloads look like this:So by doing this you get it for less but do you know if purchasing the manual includes updates when they occur? Is this method not a complete manual? Trying to weight the options.
Ah.. ok.. thanks for the explanation. I just read about the manual purchase also. It says it is time sensitive and will not provide updates. Hmm.. options.. options.By doing the pay for 3 day thing you have access to the entire Tech Authority site. You don't download a MANUAL per se. you actually have access to the Tech's see. So for example you see an INDEX when you login and you have to search by Electrical, Body, etc and then you see the diagrams etc and can PRINT to PDF. So for example you will downloads look like this:
